Using stock gauges with an engine conversion
10-03-2013, 03:56 PM
Yes..
Needs a cable drive for the speedometer (I've seen an ae86 cable stuffed into a CA18 gearbox working), but without a different ratio gear it will show the wrong speed for sure.
Tachometer can be used with ECU signal with a tach signal booster.
Messages In This Thread
[] - Ivan141 - 10-03-2013 03:56 PM
[] - Jezza_hr - 10-03-2013, 05:42 PM
[] - Escy - 10-03-2013, 10:20 PM
[] - ditn - 10-03-2013, 11:34 PM
[] - fax0815 - 10-04-2013, 01:10 AM
[] - Ivan141 - 10-04-2013, 10:43 AM
[] - Jezza_hr - 10-04-2013, 03:42 PM
  20v Blacktop conversion.... Mylesmck 0 541 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 2,417 02-08-2024 10:30 AM
Last Post: r.ave
  Digital speedometer on stock dashboard FanIsHere 0 1,534 11-09-2022 01:36 PM
Last Post: FanIsHere
  AFM to Map Conversion ps13michi 3 3,438 01-06-2022 10:34 AM
Last Post: ps13michi
  82mm Stock compression Pistons apardal 4 2,966 11-24-2021 04:26 PM
Last Post: apardal
