Valve Springs upgrade question..
07-01-2010, 08:45 PM
hey Robokill... thanks...
THese springs are having higher tension so i'm worried if i'll get the desired effect..
hoping to do a Oil Cooler setup as well...
Cheated on my いたずらな女の子 and now I can't get enough of her..
07-01-2010, 09:01 PM
oil cooler and FMIC are not rocketscience - you'll be fine accomplishing that... just a few rulez to follow as robokill stated and make sure everything is sealing properly and away you go... some simple airducts to chanel the incoming air to the coolers are also a very good idea (you can do them out of simple sheetmetal or even plastic as long as they are properly fixed to the car)
07-01-2010, 09:05 PM
Thanks bean bandit.. I will definitely look into this...
I think cooling will be a problem as my country is very warm..... so cooling will definitely need help..
07-01-2010, 09:10 PM
we usualy duct with thin allysheet and make a closed channel to the cooler - for safety reason finish the last inch with some ruber or similar to avoid the sheet cutting into something through vibration and have a little margin if you would ever bump into somthing...
something like that... http://www.dsmtuners.com/forums/attachme...p_6730.jpg
07-01-2010, 09:17 PM
that looks nice..
that's basically extending the ends of the Intercooler to the bumper right???
the rubber is towards the bumper or towards the cooler or both???
07-01-2010, 09:29 PM
Rubber on every sharp edge I would suspect. The example bean gave you doesnt look like it will seal off or guide as much as possible, but it will prevent air from going around the IC, so it's very likely going to help.
07-01-2010, 09:49 PM
sounds good bro...
same concept goes for the oil cooler i guess..
07-03-2010, 01:46 PM
heshan Wrote:based on my mechanic once i add the new springs the engine will Revv much faster than stock after 5k...
Not sure if its true or not... its tooo late for me now.. i'll have to live with the springs.. so i'll let you guys know whether its true or not..
total nonsense, can I suggest you find a new mechanic?
07-06-2010, 06:33 AM
Thumbs up!
Dan -
  4AGE Valve Buckets Scored Steller Engineering 2 990 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,510 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,363 05-25-2022 10:24 PM
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 5,982 06-23-2017 05:21 PM
Last Post: pack
  Valve clearance leon205gti 7 8,870 11-25-2016 03:24 AM
