Valve sound
03-22-2007, 02:30 PM
Valve sound
Could be a simple ticking of valves.
If it is Tic tic tic tic, the noise probably comes from the valves.
If it is Toc toc toc, defenately conrod bearings and you shouldn't use the engine anymore, replace them and check for wear in the conrod journals.
Best regards
03-22-2007, 02:35 PM
Valve sound
Does valve lash become less when the engine warms up? I didn't think so, only on engines with hydraulic lifters? Dumb question
03-22-2007, 02:39 PM
Valve sound
Apardal
you made me anxious
I cannot understand if it is tic tic tic or toc toc toc. Everyone understands it on its own way. But i think you are wright.
Maybe if i adjust my valves to see if it stops. If not then i have to dissable the engine Banging head Banging head Banging head Banging head Banging head
03-22-2007, 02:42 PM
Valve sound
NoHachi Wrote:Does valve lash become less when the engine warms up? I didn't think so, only on engines with hydraulic lifters? Dumb question
Yes, will be less due to elongation of valve stem (thermal reason). That is the reason of lash existence :wink:
Hydraulics have no lash - but they can make sounds at start due to oil starvation in the first 3-4 seconds.
03-22-2007, 04:47 PM
Valve sound
Ah , that makes sense. Thanks Jamie. Smile
03-22-2007, 05:18 PM
Valve sound
This ticking sound from the valves can continue for very long time if you use an thick oil grade
Try changing it to 10W40 or even 5W40 since the engine should be pretty young and the tolerances very narrow. Oil is too thick to support the hydraulic valve lifters.
Bearingsounds are less when cold and harder when thick overall.
03-22-2007, 05:20 PM
Valve sound
There is a possibility that during the rebuilt the lifters have changed place...
I mean that one (or more) took one each others place.
Mechanical lifters as much as the cams holders, should never change place.
I had a simillar problem once.
This is very easy to see.
Take the valve cap off, take a filler and measure every one off them.
If two of them have no normal gaps, take the cam off and change place of the lifters.
If more of two or everyone has "bad" gap then you have to readjust the valves...
Hope I help, and hope this is the problem, because it really easy to fix...
[Image: AEU86 AE86 - Valve sound]
03-22-2007, 05:24 PM
Valve sound
Yes it does...
03-22-2007, 09:33 PM
Valve sound
E-volve Wrote:This ticking sound from the valves can continue for very long time if you use an thick oil grade
No offence - just to clarify - all 4AG(Z)E uses solid lifters (not hydraulic).
03-22-2007, 10:02 PM
Valve sound
I was thinking to put a thiner oil.
I am starting by changing oil, then valve adjust and if it insists then we go for ..... Banging head
  4AGE Valve Buckets Scored Steller Engineering 2 882 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,348 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,160 05-25-2022 10:24 PM
  Valve clearance leon205gti 7 8,573 11-25-2016 03:24 AM
  16v oversize valve seats harkes 9 12,409 09-20-2016 05:04 PM
