Velocity Stacks - Which, Where, How much?
04-29-2008, 04:29 PM
I just bought an ITB setup for my engine and I'm looking for velocity stacks for it. Besides T3, which stacks and where can I buy for silvertop?
Are there any carb stacks that can bolt on this setup? They come a lot cheaper than T3, for example, and look the same. I'm just not sure about the size and bolt pattern. Best regards |
04-29-2008, 05:25 PM
I will follow this. i have also silver itb´s and need the stacks:-)
04-29-2008, 05:26 PM
I'll go for these:
![]() They are €200 for the set... Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
04-29-2008, 05:27 PM
04-29-2008, 05:44 PM
Jan, you just missed the where question!!
![]() By the way, what's the inside diameter of the ST ITB's? I heard it was 43mm... and the BT 45mm... Not sure though! |
04-29-2008, 06:15 PM
48 both.
Inside Diameter,yes. The diference is on the holes. for S/T you can use from Peugeot, the holes are the same. You only have to slighty modify the lip (top end) of the velocity stack, because you are going to have a small contact there.... ![]() |
04-29-2008, 07:41 PM
I've heard that it was 45 and 48 mm
![]() Apardal, well maybe i didn't quite answer you question but unless you are interested in these stacks and are willing to pay €200 for them there isn't much point in telling you where to get them ![]() I can order them here in Denmark if you want them... Here is a link: http://www.sitecenter.dk/sjctoyota/hjemmeside/ Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
04-30-2008, 12:27 PM
Measured them yesterday and the biggest inner diameter at the top is around 46.5mm.
Best regards |
04-30-2008, 03:38 PM
apardal Wrote:Measured them yesterday and the biggest inner diameter at the top is around 46.5mm. My measure with Vernier caliper is 47mm |
4age 16v engine which is it ? | Apsogos | 12 | 16,532 |
11-03-2014 12:13 PM Last Post: Apsogos |
Which Color??? | oldeskewltoy | 11 | 12,979 |
05-27-2014 04:22 AM Last Post: AlexKTM |
which is the best quality flywheel brand for 4age smallport? | LyndonAE86 NZ | 8 | 13,546 |
12-06-2012 01:20 AM Last Post: Bean |
How much did you paid for you TOYOTA AE86??? | kennedy8383 | 11 | 12,364 |
09-07-2011 09:16 PM Last Post: fax0815 |
How much you recon this rare set SSR CASABLANCA rims worth? | FT86 | 10 | 15,274 |
04-29-2011 02:05 PM Last Post: FT86 |
