What Part is this for my Blue Top 16v?
09-21-2008, 06:33 PM
I have a 1985 Corolla GTS but the engine i just bought is out of a i have no clue it was most probably a MR2 cause the T-VIS i got was backwards but i dunno which one i should use for my corolla gts cause i have 2 different parts that go into that same spot
In this image the upper left one is off of the engine i got 2 weeks ago that red cap is plugging fuel the yellow tape is pugging air and the green clip is a sensor the one on the lower right is out of my last blue top and it only has 2 sensors not before my last blue top my mechanic may have taken it off of the red top i had before that? ok in this pic the 2 parts switch sides, the upper left one is off of my last bluetop? redtop? and has 2 sensors and a coolant hose on the bottom and the one on the lower right has a sensor, air line and red cap. basically what are both parts called? which one should i put in my 85 Corolla GTS?[/img] |
09-21-2008, 09:17 PM
This is where the part goes onto the cylinder head |
09-22-2008, 04:10 AM
That looks like the rear oil junction where the temp sensor for the gauge goes on.
Remember to get the appropriate gasket for that. Fully Restored 1985 Corolla GT-S 1987 328ci SR20DET Drift Car 1989 Honda Civic Si-R Current Project 2002 Corolla CE Daily Driver http://www.TheTunerSource.com |
Red top in the ae86 | gh0st | 25 | 11,177 |
08-08-2022 08:43 PM Last Post: gh0st |
Replacing Top Windscreen Moulding | chrisae86 | 2 | 2,128 |
06-18-2022 08:56 PM Last Post: chrisae86 |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 7,587 |
Silver top low idle | AlexFourTwenty | 7 | 10,339 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
AE86 top mount | totta Crolla | 0 | 3,422 |
11-10-2016 08:04 PM Last Post: totta Crolla |
