What arches can be fitted?
06-03-2008, 06:23 PM
Hello, I'm quite in a hurry, I need answer till tomorrow, so the question is what arches (front and rear) is the closest to originals? Will the golf's mk2 arches fit?
Wave
06-03-2008, 07:35 PM
Closest to stock is Starlet EP7 IMO
[Image: AEU86 AE86 - What arches can be fitted?]
06-03-2008, 08:22 PM
Ford escort mk3 arches look pretty similar too.
06-04-2008, 02:04 AM
i also seen and ppl tell me that silvia s12s are similar
06-04-2008, 05:02 AM
Not quite sure if you are referring to plastic wheel arch extensions, but if you mean the OEM guard lips, I am reliably informed that the front left guard wheel lip is the same as the rear right and the front right is the same as rear left.
Thus you can use a front guard as a donor for a rear rust repair.
Haven't done it myself, but holding a front guard up to the rears, they certainly look close.
06-04-2008, 07:54 AM
Parrot is right. Left front arch fits right rear and so on. Its a rather expensive fix, though Smile
06-04-2008, 12:22 PM
Perhaps, but I have got a reasonable guard with a bad section at the bottom near the door that would be a good donor.
It's all relative I suppose.
06-04-2008, 12:54 PM
Mine problem is that not even one arch is repairable, so I need to find the closest matches to all 4 arches, and situation about both side step panels is the same Banging head
Wink Can Wing Mirror Glass be Replaced? chrisae86 1 1,136 03-05-2023 09:34 PM
  Can you convert your 86 back too the original state? gh0st 7 2,700 04-25-2022 04:25 PM
Last Post: gh0st
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 7,689 12-19-2021 11:58 PM
Last Post: gh0st
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,284 09-08-2021 12:48 PM
Last Post: Ryo
  can i just slam a oem turbo on it ? MC_JP 3 5,962 12-17-2014 11:04 PM
