What arches can be fitted?
06-03-2008, 06:23 PM
Hello, I'm quite in a hurry, I need answer till tomorrow, so the question is what arches (front and rear) is the closest to originals? Will the golf's mk2 arches fit?
06-03-2008, 07:35 PM
Closest to stock is Starlet EP7 IMO
Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
06-03-2008, 08:22 PM
Ford escort mk3 arches look pretty similar too.
06-04-2008, 02:04 AM
i also seen and ppl tell me that silvia s12s are similar
06-04-2008, 05:02 AM
Not quite sure if you are referring to plastic wheel arch extensions, but if you mean the OEM guard lips, I am reliably informed that the front left guard wheel lip is the same as the rear right and the front right is the same as rear left.
Thus you can use a front guard as a donor for a rear rust repair. Haven't done it myself, but holding a front guard up to the rears, they certainly look close. |
06-04-2008, 07:54 AM
Parrot is right. Left front arch fits right rear and so on. Its a rather expensive fix, though
![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
06-04-2008, 12:22 PM
Perhaps, but I have got a reasonable guard with a bad section at the bottom near the door that would be a good donor.
It's all relative I suppose. |
06-04-2008, 12:54 PM
Mine problem is that not even one arch is repairable, so I need to find the closest matches to all 4 arches, and situation about both side step panels is the same
Can Wing Mirror Glass be Replaced? | chrisae86 | 1 | 1,292 |
03-05-2023 09:34 PM Last Post: Ivan141 |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,151 |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 8,698 |
12-19-2021 11:58 PM Last Post: gh0st |
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 10,739 |
can i just slam a oem turbo on it ? | MC_JP | 3 | 6,214 |
12-17-2014 11:04 PM Last Post: oldeskewltoy |
