What bar is it?
08-07-2018, 12:27 AM
(This post was last modified: 08-07-2018 12:28 AM by FanIsHere.)
What bar is it?
Hello everyone.
Recently I bought some used chassis bars for my AE86 (front and rear strut bars and a tension rod bar) through e-bay and the seller send me also this bar, which I don't know what for it is. He said that it's for the rear underneath, so I think that he meant the rear axle -> panhard bar, but it doesn't seem like one, because it has two same ends. Does anyone know what this bar is? Follow: The story of my AE86 |
08-07-2018, 01:46 AM
What bar is it?
Think this is meanth to go between the C-pillars on the hatch. They usually mount to the bolts holding the seatbelt.
Something like this https://technotoytuning.com/toyota/ae86/...86-corolla Assuming you don't have any spare mounting plates to go with it. Sent from my MHA-L29 using Tapatalk AE86 ex-daily |
08-07-2018, 07:59 AM
What bar is it?
If one rod end is bigger than the other, then it is probably one of these...
http://grp4fabrications.com/product_info...cts_id=812 Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
08-07-2018, 09:38 PM
What bar is it?
(08-07-2018 01:46 AM)Bean Wrote: Think this is meanth to go between the C-pillars on the hatch. They usually mount to the bolts holding the seatbelt. I don't have anything else. (08-07-2018 07:59 AM)jondee86 Wrote: If one rod end is bigger than the other, then it is probably one of these... Unfortunately both rod ends are the same. Follow: The story of my AE86 |
08-08-2018, 12:06 AM
What bar is it?
They could be the same size. It's been a while since I was under
the car And there is nothing else that bar could be used for that I can think of. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
08-08-2018, 02:44 AM
(This post was last modified: 08-08-2018 02:44 AM by Bean.)
What bar is it?
Can you post a close up picture of the two ends? (maybe at a slight angle)
08-08-2018, 11:33 AM
What bar is it?
What length is the bar, bearing centre to centre ?
Measure your Panhard rod to see if it is the same. An analogue brain in a digital World |
10-20-2018, 12:14 PM
What bar is it?
Hello again and sorry for disappearing, but I totally forgot about it. So..
(08-08-2018 02:44 AM)Bean Wrote: Can you post a close up picture of the two ends? (maybe at a slight angle) Here you go: https://imgur.com/8TR4bah & https://imgur.com/yj4T8bB (08-08-2018 11:33 AM)totta Crolla Wrote: What length is the bar, bearing centre to centre ? The bar is 104cm from center to center as it is now. I have to measure my panhard rod, but I have to lift the car firstly. Do you know maybe what's the lenght of a stock AE86 panhard rod? Follow: The story of my AE86 |
Bash bar for zenki trueno bumper | gh0st | 3 | 1,352 |
02-08-2023 10:50 PM Last Post: Ivan141 |
Front Anti Roll Bar for Beams Swap | KD2229 | 5 | 6,169 |
09-20-2011 10:04 AM Last Post: Aram |
OEM sway bar thickness ?? | T_AE86 | 5 | 11,608 |
08-07-2011 04:05 PM Last Post: Hachi |
Adjustable Panhard Rod Bar | christsang7 | 7 | 10,852 |
07-12-2010 04:42 PM Last Post: eight-six |
Sway Bar ?? | juantonwan | 17 | 16,131 |
05-10-2010 05:04 PM Last Post: juantonwan |
