What brake fluid are you using in your hachi ?
06-03-2005, 10:58 AM
Ivan141 Wrote:If you will not find water in your brake system, then why does the usual brakefluid deteriorate due to water it absorbs?
Quote:unless you fill your brake master cylinder reservoir with water
Usual DOT 3,4, 5.1 fluid absorbs water through the fluid surface in master cylinder reservoir. My Honda have "humidity" sensor in this reservoir and when the levels of absorbed water were high - I was warned via red brake lamp on dash. In fact I suspect that this sensor is just some kind of fluid resistance measurement ...
DOT 5 is not hygroscopic - so this problem will not persist anymore.
06-03-2005, 03:00 PM
http://www.xs11.com/tips/maintenance/maint1.shtml
06-03-2005, 03:13 PM
Ivan141 Wrote:http://www.xs11.com/tips/maintenance/maint1.shtml
Strange - this guy says "don't use DOT 5 fluid" - in short.
He describes very bad things possible to occur - but how for example the water will go in brake system when the fluid is non-hygroscopic ? The only way can be if you pour it in the master brake cylinder tank (a joke :-)).
Also reading things about calipers etc - are there some real stories about such a problems ?
PS: Anyways I don't plan to use DOT 5 but I learned interesting facts from this link - and some of them are anxious !
06-03-2005, 05:23 PM
Well, condensation could be a possible entry point for water...in the fluid reservoir. There is always a good reason why things such as DOT 5 brake fluid are not mainstream daily driver accepted. If costs where the only problem then there would still be lots of cars using it.
If you think about it there isnt much reason to use it anyway, there are plenty of good brake fluids in dot 4 and dot 5.1 out there..
06-03-2005, 05:28 PM
dot 4
  PWR light issue and no brake fluid after winter storage magpie 10 2,734 05-25-2023 08:09 AM
  Can you convert your 86 back too the original state? gh0st 7 2,991 04-25-2022 04:25 PM
Last Post: gh0st
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,090 08-19-2018 12:08 PM
Last Post: AlexKTM
  What suspension set up are people using? kazi 8 8,191 07-06-2017 05:26 AM
Last Post: headrush
  How would/have you rebuild your 4age? joaotcgt 6 8,972 07-21-2015 10:40 AM
