What is cranking compression on 10-1 4AGE?
03-16-2015, 10:22 PM
(This post was last modified: 03-16-2015 10:23 PM by oldeskewltoy.)
9.4 to 1 compression 4AGE has a 179# measurement, while the 10.3 to smallport 4AGE has a 190# measurement.
What is the cranking compression on a 10-1 4AGE - looking for a FSM reading/reference - I can guess and say 185 or so, but I was hoping for a measurement from the FSM anyone????? Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-23-2015, 06:09 PM
When mine was running it was putting out from memory, 182-183
My compression is not standard but it's about 10.15 |
03-24-2015, 10:18 AM
I knew an engine which only had 10000km
He did a warm compressiin test and had 187 on all cylinders complete stock |
82mm Stock compression Pistons | apardal | 4 | 2,912 |
working out compression ratios | kazi | 2 | 3,668 |
07-16-2019 08:22 PM Last Post: oldeskewltoy |
Distributor position and cranking | pack | 13 | 19,425 |
07-01-2013 11:08 PM Last Post: pack |
What fuel are you high compression guys running? | 4000GT | 18 | 16,590 |
09-04-2011 07:11 PM Last Post: IBMFD3S |
7age 16v compression | Pif | 1 | 4,750 |
10-12-2010 09:37 PM Last Post: Pif |
