What is the cylinder head x engine block torque specifcation
11-11-2007, 10:23 PM
Hello,
I need to know what is the torque specification for the bolts from cylinder head x engine block. I think it's 30 N.m more 90º and more 90º... Keeping the AE86 alive! |
11-11-2007, 11:22 PM
removed wrong values
It's on page EM-117 of my 4AGE manual, but perhaps you can find it here as well: http://files.aeu86.org/manuals/4A-GEManual.pdf 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
11-11-2007, 11:57 PM
That's strange banpei...
I have a RM from the 4AFE and 4AGE engine (for the Celica, Carina and Corolla i think) and it says that the torque is 30 N.m, then 90º and then another 90º. Very strange i think... I ask because my engine is loosing water between the cylinder head and engine block immediately after start. Keeping the AE86 alive! |
11-12-2007, 01:06 AM
AE86 engine bay stickers
![]() 300kg +90/+90 or see manual!!!! which tells you something else An 86 is for Life, not just for Christmas |
11-12-2007, 01:55 AM
2 figures...
I supose they are equivalent... Keeping the AE86 alive! |
11-12-2007, 06:03 PM
Ah, I see my error...
![]() Looked at the wrong head: info I gave you are for the 8-valve head. Correct value would be 300kg/cm (22 ft/lb, 29 N.m) if you look at page EM-117 in the manual. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
11-13-2007, 11:47 PM
OR... if you have an olde manual you will note the head to block torque is 44#s. Btw... the head bolts NEVER changed part numbers... so new ones are not TTY. I used 44#s when I built my engine 5 years ago.... no head gasket or overheating issues.
I believe.... the new spec is cause there were too many STUPID techs who didn't think to do the head bolts in 3 passes(25, 35, 44). The new spec pretty much requires them to do it in 3 passes.......... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-14-2007, 11:21 AM
Well, but it's tough to make the 3rd pass (last 90º).
4AGE cylinder head plug removal | Ivan141 | 5 | 2,380 |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,824 |
4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 90,560 |
05-05-2019 04:03 AM Last Post: Rocker100 |
BT head with ST block. | CHOPKIN2 | 6 | 7,551 |
02-06-2018 06:27 PM Last Post: mad.matt |
Brake advice - master cylinder | mannix20vt | 12 | 14,818 |
