What is the length of the coilover springs??
12-04-2009, 01:09 AM
FRONT TRD 7kg springs on this video at 00:44:
http://io.ua/vc0012b43d8dc48f1fd0141a7cb75474a
REAR '...' 6kg springs on this video at 01:20:
http://io.ua/v6d95fa71a29fcf4856387d1e06a84d8e
In advance, thanks a lot!
[Image: AEU86 AE86 - What is the length of the c... springs??]
http://ae70.blogspot.com/ & http://drft.io.ua/
12-11-2009, 12:23 AM
I didn't see the video, but you can run coil-over springs any length you want.
In my AE86, the front springs are 250mm long, others run 200mm long springs. Off road rally cars often run longer springs than this (due to longer travel). This does not dictate the ride height at all. That is to do with the placement of the threaded sleave, which you can weld anywhere you like, and the threaded adjustement.
12-11-2009, 02:46 AM
Get them as long as you need to not coil bind IE they "stack up" before the shock travel is used up. Thats why rally cars have the long springs, Jonny said.
Wow, I could have sworn I had an account here... I guess I'm the new guy Sad
12-11-2009, 10:47 AM
Its difficult to calculate or check whether you are getting coilbind.
Coilover springs are usually only rated between 60-90% of their length, you want to make sure that all of your handling loads fall inside that range.
Coilbind is then only used to determine where your bumpstops need to engage.
Easier to just measure the TRD spring for the guy Smile
from experience I would say that the fronts would have to be a minimum of 8 inches long with 9 inch rears. If you dont intend to build a trailer queen then you might want to add an inch to those numbers otherwise you end up with a range of adjustment between slammed and scraping the groundSmile
People running 200mm springs require 7kg/mm rear springs to keep them in spec range.
12-11-2009, 12:10 PM
Understood!
Thanks for the information...
As the front I ordered these:
Manufacturer: TEIN
Free length: 250 mm
Diameter: Φ 65mm
Spring Rate: 8.0kg/mm
Other: TEIN CS harmonic drive genuine front springs.
Now for the rear axle I looking for 6kg/mm.
They should be in the district for 250-300mm long, right?
12-11-2009, 12:14 PM
In all the characteristics for my AE70 I try to emulate the characteristics of the Ueo's AE86. http://www.youtube.com/watch?v=OM302VsjOWg
  Rear arm length totta Crolla 7 1,129 06-05-2024 08:53 AM
Last Post: totta Crolla
  HKS valve springs totta Crolla 3 2,216 05-25-2022 10:24 PM
  Springs from other vehicles?? FanIsHere 16 14,497 05-17-2016 09:12 AM
Last Post: FanIsHere
  4AGE 20v Ignition Lead Length mad.matt 3 6,636 10-01-2014 03:43 PM
  Door length Ivan141 3 4,944 03-18-2014 02:11 PM
