What is this part...
06-29-2014, 10:10 AM
(06-28-2014 09:18 AM)Bean Bandit Wrote: Seriously just go down to your local store and buy what ever they have in mid price range and around 60amp (45minimum). Just installed a new battery. Always the same. Doesn't start. :-(:-( I turned the cranck whith a wrench to help the starter to engage the flywheel and sometime by chance it start. My alternator is in good condition. So, i guess the problem come from my starter ? What you think ? From which car come this 1G series from ? Envoyé depuis mon GT-I9100 avec Tapatalk |
06-29-2014, 01:08 PM
Bad ground connections would be the next thing to check... Results in similar problems as a bad battery.
06-29-2014, 03:52 PM
What is this part... | |||
07-05-2014, 07:05 PM
New battery, Alternator OK, New starter, Ground Wiring OK.
Car won't start when cold. WTF...... Please help :-( :-( :-( |
07-06-2014, 04:57 PM
(07-05-2014 07:05 PM)izanagi Wrote: New battery, Alternator OK, New starter, Ground Wiring OK. Mine had hard times cranking especially when hot (turned maybe 1rev/sec). I made a direct ground cable from the gearbox to the ground of the battery... problem solved. |
07-06-2014, 06:49 PM
Ok. Some news.
The "click" noise that i was hearing come from the circuit open relay and now the start pinion hitting the flywheel. I will replace the relay and see what it happen. Envoyé depuis mon GT-I9100 avec Tapatalk |
