What power will a TRD 2 Way handle?
10-04-2014, 09:34 PM
Hey folks.
What kind of power torque will a Trd 2 way handle?
Diff has done 2k Miles.
And has also been built up into a new casing with a brand new CW&P by 20v Will.
And done zero miileage since.
Cheers.
[Image: AEU86 AE86 - What power will a TRD 2 Way handle?]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
10-04-2014, 10:41 PM
More than the half shafts Wink
10-04-2014, 10:43 PM
Lol
250 bhp and 250lb torque is what I'm thinking of.
10-05-2014, 12:12 AM
If you want to be on the safe side of things you might want to consider the heavy duty custom weir axles from weir performance. Though I think the stock kouki axle will take the load fine as long as you don't clutch kick the shit out of it with a twin plate.
10-05-2014, 06:36 AM
Hmm not a twin plate.
But it does have a helix cerametalic paddle clutch in it.
10-05-2014, 11:43 AM
As long as it's a sprung one it will lessen the initial beating on the drive train.
In any case the diff will take the punishment as long as it's a kouki model. If you brake a half shaft down the road you can still go bigger. (I doubt it will be necessary though).
10-05-2014, 11:53 AM
1984. So a Zenki.
10-05-2014, 09:00 PM
(10-04-2014 10:41 PM)Bean Bandit Wrote:  More than the half shafts Wink
Thumbs up!
10-05-2014, 09:15 PM
is the TRD on offer also a zenki? - IMHO the Zenki will not be up to the job, so an upgrade would be advisable. If your budget allows you might want to go for the weir axles and be done with it.
The weir axles have been successfuly used by drifter with SR20DET conversion so you should be fine.
10-08-2014, 04:17 PM
It's an early axle as well.
  Is there a way to move separate posts? Ivan141 6 7,047 06-23-2005 09:56 AM
