What radiator to use??
07-09-2007, 07:53 PM
just use a standard 4age one. I have driven over 4 hours of circuit time without problems. As long as you keep the fan on the waterpump your engine won't overheat.
07-09-2007, 08:18 PM
I'm with Mux. I once used a Rx7 1st gen radiator in my Ae86. Although ivan is perfectly right about the bigger diameter of the piping, fitting them was a piece of cake.
Very easy but hard for me to explain, i'l try anyways ![]() 1. Get the correct pipe that fits the rx7 radiator. 2. Buy a round metal pipe that goes inside the original piping of the hachi as reinforcement where you put the clamps on. 3. Put a piece of metal pipe in the hachi piping. Put the hachi size pipe inside the bigger rx7 pipe, and off you go. He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which. |
07-09-2007, 08:21 PM
It costs $1700.00 nz for a new radiator for an ae86 and $75.00 for a new mk2 golf radiator from a local. The inlet and outlet are both on the left like an AE86. Im not familiar with PRESSURE TANK, whats this for?
07-09-2007, 09:52 PM
I believe the golf radiator uses an external pressure tank that also holds the pressure cap for the cooling system.. the ae86 radiator has the cap right on top of the radiator and doesnt need an external tank (although it has a little expansion reservoir).
07-09-2007, 10:07 PM
there is a group buy on another forum, on alloy rads, sent banpei a PM asking him if its allright to post the info on forum
![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
07-10-2007, 09:15 AM
BigYin,
its alreade posted in sell I think ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
Radiator & grill support panel (Levin) | FanIsHere | 5 | 2,382 |
11-14-2022 10:07 PM Last Post: Ivan141 |
Alu thick core radiator fitment | Gtsi-R | 5 | 3,248 |
01-26-2022 01:28 PM Last Post: Gtsi-R |
AE86 F20C swap - Radiator issue | mad.matt | 3 | 6,180 |
02-07-2018 05:14 PM Last Post: mad.matt |
Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 6,074 |
cool lower radiator hose | thanos | 4 | 5,749 |
