Wheel studs
01-22-2007, 08:44 PM
Wheel studs
This is an "up" for this old topic.
I want to buy longer wheel studs for my hachi and I made a search on ebay. They sell only for the S13, some Hondas and Nissans...at least I haven't found more.
They say different sizes for them like 12x1,25 and 12x1,5, regarding Ivan's post, the 1,5 is the stock pitch for the hachi? And how long studs should I buy if I plan to use some 2cm spacers and which "head" shape will fit the hachi?
1987 Toyota Corolla GT coupe - for holidays oversteer
2005 Toyota Corolla - for daily understeer
01-22-2007, 10:25 PM
Wheel studs
If i want to use 7mm spacers i dont need longer studs?
01-22-2007, 11:23 PM
Wheel studs
We tried with 6mm spacers and studs were long enough. Depends of rims.
8mm spacers were too thick for stock studs. I can find +5mm longer studs locally. But not any longer than that.
01-23-2007, 12:02 AM
Wheel studs
For my supra celica rims
01-23-2007, 11:47 AM
Wheel studs
6mm will work.
7mm - possible but I will not use them.
PS: the Supra rims have good offset and are wide - why you need to use spacers ???
01-23-2007, 12:13 PM
Wheel studs
Does anybody know the answer for my question as well? See 4 posts upper.
01-23-2007, 01:09 PM
Wheel studs
SutteR, I have hub off the car (spare), will remove stock stud and measure the slotted part diameter(the part which is pressed on the hub).
Will measure the length too and calculate your desired length.
01-23-2007, 01:23 PM
Wheel studs
May thanks in advance jamie!
(What about the roll cage? Sent a PM yesterday.)
01-23-2007, 01:24 PM
Wheel studs
offtopic:
read the PM, waiting the owner (I'm not the owner - the car+cage belongs to my friend here) to decide.
12-20-2007, 10:28 PM
Wheel studs
Will the LandCruiser studs work without spacers? I need to find some long studs for my coupe and they seem to be nearly impossible to find, esp. since toyota stopped selling them in dealerships. =/
I have also heard that 4runner studs work for hachis... is that right?
AJC
'85 GTS coupe - ghetto and half broken | '86 SR5 hatch - soon to be swapped & caged
My Website
My Myspace
  ARP Head studs in a N/A engine, necessary? Jimmi The Kid 13 14,998 02-04-2013 11:27 PM
Last Post: Jimmi The Kid
  Longer studs Eric 4 5,971 04-29-2011 07:35 AM
Last Post: Eric
  longer wheel studs fax0815 8 10,792 02-17-2011 09:57 AM
Last Post: max_ae86
  How to fit rear wheel studs without removing the shafts? Slipangle 3 5,042 11-19-2010 10:29 PM
Last Post: Slipangle
  Where to find Extended Wheel Studs. RZT86 9 11,941 07-03-2010 01:59 PM
Last Post: Sam-Q
