Wheely confused now !
11-25-2005, 12:49 PM
Just checked the "sticky" wheel thread and I'm none the wiser when it comes to 15" Supra alloys, can anyone confirm that they exist in the U.K before I spend hours trolling the breakers ? Thanks
11-25-2005, 12:53 PM
I don't know or they exist in the UK, but in the Netherlands they came under one of the Camry series, not under the Celica Supra (those where always 14" over here). I believe they only got those 15"ones under Celica Supras in the US and in Japan.
11-25-2005, 01:02 PM
There is a set of fantastic set of rims for sale in e-bay.co.uk.
Search for AE86, its at the 2nd page of search results. Go for them danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
11-25-2005, 01:14 PM
Found those wheels thanks, but I'm really looking for 15" wheels as the car is used for road rallies and needs the extra ground clearance. Although the guy has some 15s for sale I will need about 10 rims so standard ones would be my best (cheapest !!) option
11-25-2005, 01:26 PM
Uhhh....why go with 15" for the ground clearance? I've seen the front struts that came of a rally ae86 (robokill has them, I use the springs at the moment) and they had rewelded the bottom spring perches up a bit higher...may be a good solution for you since it also makes the use of stiffer (usually shorter) linear rate springs easier.
11-25-2005, 01:46 PM
Sorry Ivan forgot to mention that my garage appears to have the worlds supply of 15" tyres (complete with spiders ) in it and I'd like to use 'em up ! Re-welding the spring platform sounds like a fantastic idea to me though, thanks
11-25-2005, 03:13 PM
Velocity stacks = more power, now which to get? | 4000GT | 38 | 49,620 |
02-22-2012 01:19 AM Last Post: jondee86 |
Engine wont start - cranks OK - NOW WITH VIDEO | Apolan | 14 | 16,877 |
08-20-2010 12:51 AM Last Post: Apolan |
Battery died. Headlights now go up but not down. | Age86 | 4 | 4,678 |
09-15-2008 01:18 PM Last Post: banpei |
