Which Camberplates do fit on Koni Yellow dampers?
06-13-2007, 11:29 AM
Oh boy,.... Huh
06-13-2007, 12:01 PM
Stock TEIN nuts will not work with AE86/92 Yellow Koni (tested). Thumbs up!
maybee Tein sent me the wrong Nut. But I know for shure that my Konis ahve a thread size of
M12x1,75
and my Bilstein Dambers have a Thread size of:
M14x1,5
So please tell me how in Gods name one and the same nut can fit 2 differnt Thread sizes. :wink:
[Image: AEU86 AE86 - Which Camberplates do fit o...w dampers?]
06-13-2007, 12:42 PM
Just got a answer form Tein UK:
Quote:Hi Julian
M14 x 1.5Ps are included in the Tein top mount kit.
I am sorry, but I will need you to measure the internal diameter of the OEM piston shaft or top nut, then we can check and give you the correct part number to order.
Many thanks
Chris Marshall-Dowe
Sales
TEIN UK LIMITED
Unit 7 Avant Business Centre
Denbigh West
Milton Keynes MK1 1DL
United Kingdom
so if your damper has a Thread of M14 x 1.5Ps you are good to go!!!
06-13-2007, 12:48 PM
Good info, Kid :!:
06-13-2007, 02:43 PM
M14x1,5 is the size here. It's strange for me to see 12mm size on these Konis, this is too thin. Are you sure (PN# check) that they are AE86 and resp. 92 models ?
06-13-2007, 04:48 PM
there are 2 differnt types of koni dampers. I have both and just messured ist. The normal ones that were avalible over toyota back in the 80 are thinner then the ones you kan adjust will installed. Thumbs up!
06-13-2007, 05:59 PM
As long as they fit the standard topmounts, they should fit any camber plate you can throw at them too.
06-16-2007, 11:02 AM
Part Number from Tein for the Pillow Nuts in M12x1,25 is PMP03-91022-2
Smile
06-16-2007, 03:56 PM
@ ASH.
repost bro
06-16-2007, 04:03 PM
@kid
No, there are two types of pillow nuts available
PMP03-91022-2 and PMP03-91022-1
Big Grin
  20v BT - which oil pump? Mylesmck 4 2,616 06-21-2022 04:51 PM
Last Post: pack
  Mistlamps don't fit gh0st 1 2,236 10-14-2021 09:00 PM
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,285 09-08-2021 12:48 PM
Last Post: Ryo
  KONI Sports shocks for the AE86... jondee86 11 20,452 09-08-2017 03:38 AM
Last Post: jondee86
  Rim width. Which is best.... Dino86 5 6,706 01-07-2017 03:09 PM
Last Post: Dino86
