Which head do I have - On the car, not me!
02-07-2007, 09:12 AM
SekiguchiUeno Wrote:jamie i have one question on you, the diffrence between carbs flanges
solex vs weber.
i have addhe and my friend one weber i am not sure about type, they have identical hole diameters and positions but the mounting points dont match.
I have the TRD N2 intake manifold which was designed for Dellorto DHLA carbs but I'm using it to mount a pair of Mikuni-Solex 44 PHH carbs. They fit the flanges perfectly and the barrels line up nicely with the intake runners.
The Datsun 1200 club website says;
Quote:Conventional Sidedraft Carburetors. These are all dual-bore carbs (2-barrel). The following use the same intake manifold (same bolt pattern):
* Weber DCO/DCOE
* Mikuni-Solex PHH
* Solex ADDHE
* SK racing sidedraft
* Dellorto DHLA
02-07-2007, 12:05 PM
solex vs weber.
I have ADDHE 40s from 2TG, Weber DCOE 40s and DelOrto DHLA 40s. All they share same bolt pattern and hole diameters. Tested also with borrowed Weber 45 - bolt pattern is the same, just enlarged the hole diameter.
Recently I found some information about Solex 48s:
http://www.ruddies-berlin.de/Sportvergaser.htm
He described 2 different types - "sport" and "alfa". Browse this site and look at the pictures. Maybe Solex have some variations - I have just one of them and it fit in Weber/Delorto pattern.
  20v BT - which oil pump? Mylesmck 4 3,718 06-21-2022 04:51 PM
Last Post: pack
  Rim width. Which is best.... Dino86 5 7,555 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 8,671 07-27-2015 11:24 AM
Last Post: pack
  How would/have you rebuild your 4age? joaotcgt 6 9,984 07-21-2015 10:40 AM
  Haslbeck front spoiler, which foglights? wouter86 2 5,629 02-15-2015 11:14 AM
Last Post: ditn
