White Kouki Trueno Hatch, 20V BT, FC3S brake, Watanabe MG,
12-14-2010, 01:22 PM
Back to body work Thumbs up!
[Image: AEU86 AE86 - White Kouki Trueno Hatch, 2...tanabe MG,]
12-14-2010, 01:44 PM
Here is my prepared front strut Yummie!
TEIN ball joint and spring
JIC shock absorber
RX7 FC3S 4 Pots disc and caliper Thumbs up!
and here is the rear one
12-14-2010, 04:04 PM
Seats - is my DREAM! Smile
Which companies are shock absorbers?
http://ae70.blogspot.com/ & http://drft.io.ua/
12-14-2010, 04:27 PM
DRFT Wrote:Seats - is my DREAM! Smile
Hi, The rear shock absorber Im not sure with brand but Kayaba was its maker, and spring also, it was light blue from japan before I repaint it so I guess it is TRD. I took this set from drift car in Japan Smile
for the front, as I said it is JIC shock absorber with tein spring
12-15-2010, 06:35 AM
a little update Cool
and I will use this, 3M automix panel boonding, it just like a spot welding but no corrosion, a bit costly
12-16-2010, 04:26 PM
To use 3M panel bonding
first all seal and color need to be removed. Then taped the area
engine bay Hurray!
12-18-2010, 06:13 PM
painting interior Hurray!
first, base paint
followed by enamel paint
Then Lacquer
12-18-2010, 06:18 PM
Thumbs up! gj seeing another hachi being restored. hows the bottom of the car?
12-18-2010, 07:04 PM
Surface preparation for the real enamel paint
in painting room Cool
12-18-2010, 07:08 PM
robokill Wrote:Thumbs up! gj seeing another hachi being restored. hows the bottom of the car?
Hi, Thanks for comment Big Grin
for the bottom of the car, as I have checked it still in good condition so I think only rust preventing coat will be enough for this hachi, or do you have any suggestion for the bottom of the car? Hurray!
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 14,947 10-07-2018 09:45 PM
  Adam's white, rusty levin...updated 23-09-2018!! adomz 150 149,151 09-23-2018 05:14 PM
Last Post: adomz
  86er Levin Hatch from Germany ArToAE86 19 16,437 01-24-2018 10:35 PM
Last Post: ArToAE86
  Lauren's 1985 Kouki Trueno Lauren 161 188,214 09-01-2015 08:46 PM
Last Post: Lauren
  OST-026: "My White Hatch" oldeskewltoy 49 58,496 07-03-2014 11:56 PM
