Wire color for revcounter?
07-18-2007, 12:12 PM
Hi, does anybody know which color the wire for the rev counter/tacho has? It must could be found out by the ignition coil!? Right?
Mvh Jack Blacktop, the only way to fly |
07-18-2007, 05:11 PM
thin black with red line. Goes from the igniter to the big connector on the firewall.
AE86 GTS '84 Red Top |
07-18-2007, 09:07 PM
Bad_Dog Wrote:thin black with red line. Goes from the igniter to the big connector on the firewall. Thanks:-) I have some problems with getting my rev counter work with my blacktop and megasquirt. Just cant get i work ![]() Blacktop, the only way to fly |
07-19-2007, 08:57 AM
well,
it will not work without mods 1. this is how I did it http://www.msextra.com/viewtopic.php?p=147821#147821 2. or you can use this http://www.msextra.com/manuals/MS_Extra_...ivolts.GIF Have you mapped your BT. Do you use speed density or Alpha-N? I'll be mapping an open ITB silvertop soon so any info would be appreciated. AE86 GTS '84 Red Top |
07-21-2007, 10:07 AM
Bad_Dog Wrote:well, Yes, but i have tried the 2 way you wrote. And the trick with the 3 diode's just dont work:-( Maybe i should try to look at the way you did'it. Yes my BT is mapped now. I used speed density, because the blacktop i stock. But if you use some racing camshafts you will need to use Alpha-N, because the vacum/map pressuere will be very weird:-) Blacktop, the only way to fly |
07-24-2007, 07:00 AM
zounds Wrote:Bad_Dog Wrote:well, I have tried both ways to wire tacho. Both work if set properly on an AE86. The second one works with ordinary coils (with + na - terminals). However I use COPs from 1zz with built-in igniter (so I don't have negative coil terminal). The solution was to hack the dashboard as described and it works fine on my Zenki AE86. AE86 GTS '84 Red Top |
TRD N2 color codes | ellinas82 | 1 | 7,330 |
07-19-2015 10:45 PM Last Post: Project D |
Tachometer wire colour | Jezza_hr | 8 | 15,384 |
10-13-2013 03:52 PM Last Post: parrot |
Color White or White? | Skyracer | 3 | 5,624 |
03-11-2013 04:51 PM Last Post: Skyracer |
MSD 8980 setup - which wire does the dizzy connect to? | megabob | 8 | 18,142 |
11-22-2011 07:02 PM Last Post: Project D |
color code? | slowboy2 | 1 | 4,857 |
09-10-2011 08:24 PM Last Post: xrgeorg |
