Wire color for revcounter?
07-18-2007, 12:12 PM
Hi, does anybody know which color the wire for the rev counter/tacho has? It must could be found out by the ignition coil!? Right?
Mvh Jack
Blacktop, the only way to fly
07-18-2007, 05:11 PM
thin black with red line. Goes from the igniter to the big connector on the firewall.
AE86 GTS '84 Red Top
07-18-2007, 09:07 PM
Bad_Dog Wrote:thin black with red line. Goes from the igniter to the big connector on the firewall.
Thanks:-) I have some problems with getting my rev counter work with my blacktop and megasquirt. Just cant get i work Confused
07-19-2007, 08:57 AM
well,
it will not work without mods
1. this is how I did it http://www.msextra.com/viewtopic.php?p=147821#147821
2. or you can use this http://www.msextra.com/manuals/MS_Extra_...ivolts.GIF
Have you mapped your BT. Do you use speed density or Alpha-N? I'll be mapping an open ITB silvertop soon so any info would be appreciated.
07-21-2007, 10:07 AM
Bad_Dog Wrote:well,
Yes, but i have tried the 2 way you wrote. And the trick with the 3 diode's just dont work:-( Maybe i should try to look at the way you did'it.
Yes my BT is mapped now. I used speed density, because the blacktop i stock. But if you use some racing camshafts you will need to use Alpha-N, because the vacum/map pressuere will be very weird:-)
07-24-2007, 07:00 AM
zounds Wrote:
Bad_Dog Wrote:well,
I have tried both ways to wire tacho. Both work if set properly on an AE86. The second one works with ordinary coils (with + na - terminals). However I use COPs from 1zz with built-in igniter (so I don't have negative coil terminal). The solution was to hack the dashboard as described and it works fine on my Zenki AE86.
  TRD N2 color codes ellinas82 1 6,831 07-19-2015 10:45 PM
Last Post: Project D
  Tachometer wire colour Jezza_hr 8 14,018 10-13-2013 03:52 PM
Last Post: parrot
  Color White or White? Skyracer 3 5,034 03-11-2013 04:51 PM
Last Post: Skyracer
  MSD 8980 setup - which wire does the dizzy connect to? megabob 8 16,987 11-22-2011 07:02 PM
  color code? slowboy2 1 4,419 09-10-2011 08:24 PM
Last Post: xrgeorg
