Wrong Ignition Timing consequences !?
01-04-2008, 11:34 PM
Car choked and didn't go so well and I changed ignition timing without knowing how much. Now the car goes like crazy, engine never felt so "powerfull".
I can't tell what is my ignition timing because crank pulley is all warn and cracked (I know, I will change it eventualy). So are they some bad consequences of advance ignition timing ... or any wrong ignition timing from stock (10 BTDC). Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
01-04-2008, 11:57 PM
too much advance could possibly kill your engine, but I think you'd have noticed the noise and starting problems that would cause. Some time ago, I remember robokill was driving around with his timing inadvertently set to about 5 degrees ATDC. Which wont harm anything other than performance.
01-05-2008, 12:31 AM
Ivan141 Wrote:I remember robokill was driving around with his timing inadvertently set to about 5 degrees ATDC. Which wont harm anything other than performance. AFAIK and some overheating probems... if you push it hard. Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
01-05-2008, 08:20 PM
yea if the timings out - or + it could corse pinking or a lack in performance!
you just lucky i guess 2 get it spot on by the sounds of it ![]() the rite timing for yr engine is -10btdc |
Ignition switch plug and wires | Blaze0010 | 3 | 586 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 14,073 |
4agze timing | leon205gti | 11 | 14,089 |
04-07-2017 03:10 AM Last Post: jondee86 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,401 |
extracted freedom ecu 16v ignition map | ditn | 7 | 9,292 |
