about TRD Lsd identification
05-17-2010, 11:50 PM
I need help to know the LSD Type shown on pics
I know it's a TRD
But what type : 1 way , 2 way .....?
Thanks for helping
Phil
Filh
Save the RWD cars
05-18-2010, 01:30 AM
2 way for sure Wink
It is really late for me, so I will explain in French, sorry for people who don't understand french...
regarde sur ta 2nd photo, les 2 pièces en haut.
l'endroit ou se positionne les axes de satellites (les petit pignon) sont en V parfaitment symétrique donc 2 voies Wink
si c'était 1 voie tu n'aurai un demi V ( |/ au lieu de \/)
et un 1.5 voie tu aurai un V non symétrique (un coté plus prononcé que l'autre)
05-18-2010, 02:34 AM
ça c'est de l'explication , grand merci à toi .
thanks to you ProjectD
phil
Filh
Save the RWD cars
05-18-2010, 09:42 AM
Does TRD have anything other than 2way ?
I think not.
05-18-2010, 10:32 AM
They sure do..1.5 way also.
This is a two way..you can see the two diamond shape ramps (ramp angles) on both diff halves. They are exactly the same, hence two way. I guess projectD said something along the same lines. You can see them in the second pic. The two thingies at the top.
05-18-2010, 11:22 AM
You're right, just checked:
Zenki 2way
41301-TA005
Zenki 1.5way
41301-TA006
Kouki 2way
41301-AE804
Kouki 1.5way
41301-AE805
05-18-2010, 11:39 PM
I also noticed a T2 mark on cover , guess it's the abreviation for Two way .
I think I know what I need to buy .
I broke a half shaft (it's the fifth one) due to rallye use ....
And when cleaning gear end I found that LSD is cracked on the just under cover plate .
The TRD LSD is very reliable , I used it for many years in rally, without any problems,
I'll try to find an used one , on Ebay .
If you have good links , don't hesitate .
Phil
Filh
Save the RWD cars
05-19-2010, 08:13 AM
Yes Nohachi that exactly what I said, but in french Tongue
Filth, If you don't whant to break half shaft anymore see the oversized one made by weir performance. :wink:
05-21-2010, 01:15 AM
Yes I saw the big half shaft , but I'm not sure it's the solution for me . Ionly have 135hp, but it's the way I drive in rally that lead to the half shaft explosion....
Angry
phil
Filh
Save the RWD cars
  LSD identification FanIsHere 3 666 04-19-2024 06:14 PM
Last Post: Blaze0010
  Valves identification FanIsHere 1 2,783 10-29-2020 06:18 PM
  Brake calipers identification FanIsHere 4 4,135 10-23-2020 11:45 PM
Last Post: FanIsHere
  Piston Identification Alex170984 3 5,272 05-17-2016 12:47 PM
Last Post: Alex170984
  Removing unnecessary wires.. some identification help! 4000GT 3 4,993 08-20-2011 04:40 AM
Last Post: 4000GT
