ae86, 6 speed, turbo
03-23-2012, 01:22 PM
hey!
a wee project ive been muching around with for the last year! dont have any good before photos just yet but it was completely std, plenty of rust ![]() modifications ive done are: full strip and re paint all new lights (genuine) repaired all interior flaired front gaurds flaired rear gaurds custom front bumper engine: 4agze block, rods, crank modified 4agze pistons smallport head bluetop cams trd valve srpings evo 9 560cc injectors bosch 055 fuel pump cusotm intercooler and piping custom inlet manifold sr20de throttle body link g4 computer with display link 4 pot front brakes 320mmx32mm disks cresida struts koni adjustable inserts coil over platforms front and rear re designed rear suspension geometry 15x8 wheels(to be changed) mr2 rear brakes 6 speed altezza gearbox on custom belhousing 225mm 6 puk firction plate re pressured cover custom lightweight driveshaft hilux diff custom lsd 2 way unit to be done: custom ex manifold td05h t3 turbo full stainless exsaust tail wastegate so many other things but thats the majors ![]() a few snap shots, havent got any of it on the hoist with suspension complete but should have some in the next week or so. hopefully get it started this weeekend if i get into gear and make the ex manifold ![]() everything was done in my garage by me ( minimal parts brought ) all thoughts are welcome! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
03-23-2012, 03:31 PM
Looks great
![]() Do you have picture of MR2 rear brakes installed please? Did you use disc and caliper from MR2? Is it plug and play? which model did you use please? Mine (OE) are in bad condition so I'm considering to change / upgrade. Thanks. |
03-23-2012, 07:29 PM
Nice Pal cool build Cheers !
03-23-2012, 08:07 PM
Wow that's an impressive build !
03-24-2012, 09:39 AM
hi yes mr2 sw20 turbo model disc and caliper (vented disc)
i can get a picture once i out it back on the hoist, the are not a bolt on item, required re drilling of stud holes , and machining of axels to suit disc. then a brake mount made, bearing in mind this has a hilux diff so not sure how they would go bolted onto an ae86 item. handbrake cables are a chalenge on the mr2 setup id sugguest making a setup with internal drum handbrake ![]() UPDATE!! finally recieved the turbo today! had work so only got a few hours to work on it! first turbo manifold ive made so its a learn as i go ![]() ![]() ![]() ![]() ![]() ![]() hopefully get the manifold done and faced tomorrow then its exsaust time! |
03-24-2012, 09:46 AM
I did make mine hilux axle whit Altezza brakes. quite big solid disk. 2pot caliper and best of all with internal drum handbrake. Not bolt on setup but nice to do. new holes disk, little modifying to get "back plate" to work whit hilux/hiace axle. And make mount the caliper.
I think handbrake cable work of ke70? i must find pair somewhere in garage and check.. |
03-24-2012, 01:16 PM
Good skills, DIY is the best
03-25-2012, 09:45 AM
progress today!!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() opinions on the wheel situation would be awesome!!!! |
03-25-2012, 10:12 AM
Hi mate, excellent build.
I have notice that you have a cooper pipe coming in to the fuel rail, you should have a flexible hose there, the cooper will fatigue and fail with engine vibration ...... |
12-24-2013, 09:44 PM
Any more on this cool build
KE70 4A-GE 16V turbo | kjb | 16 | 30,627 |
10-21-2016 01:32 AM Last Post: fantapants |
4AG 16V Turbo 15PSI Running MegaSquirt 3.0 | CHACAMAN | 15 | 24,588 |
08-14-2013 04:28 AM Last Post: daveskatesallday |
CXRacing AE86 Corolla Top Mount T3 Turbo 4AGE 16V Build | CXRacing | 5 | 10,720 |
07-12-2012 02:03 PM Last Post: mc68 |
Vellu´s AE86 turbo project | vellu | 41 | 107,634 |
08-31-2011 10:10 PM Last Post: vellu |
ae86 3sge beams turbo built v mount intercooler | boryae86 | 9 | 23,436 |
10-25-2010 02:46 PM Last Post: boryae86 |
