ae86 f20c header
08-21-2008, 02:53 PM
ae86 f20c header
Hi can anyone tell me where to get an exhaust manifold for my ae86 rhd with f20c in it????? just starting this project now......
08-21-2008, 03:51 PM
ae86 f20c header
Try honda?
Rokuichi Power !! _________________________________________ Toyota Starlet KP61 2.0 vtec |
08-21-2008, 04:35 PM
ae86 f20c header
The stock manifold is very good, but if I read Ians thread correctly, it will foul the steering column on a hachi. Looks like most people get a custom fabricated manifold.
08-21-2008, 05:48 PM
ae86 f20c header
Yep, custom job im afriad. Extend the primary runners by about 25-30mm and you wont be too far off, a few tweeks and you'll have a manifold. Do it well or you'll loose power.
Driftworks - JSPFab.com - DangerStyle - NightSpirit |
08-21-2008, 06:27 PM
ae86 f20c header
Would a stock manifold fit without mods on a LHD corolla?
No Smorking AE86 |
08-21-2008, 07:29 PM
ae86 f20c header
Yep - they fit absolutely fine on LHD corollas - saves you a pretty packet thats for sure - but if you get one built I recommend you use RS Fabrications...they did a great job for me - I can even remove this from the car with the engine in place. The problem is the output from the steering rack and the main steering column itself for us RHD boys. I believe ROCO performance over in Ireland have modded 2 stock s2000 manifolds to fit - but I dont know if anyone has power figures for them yet - but suspect a loss.
The runner lengths are from a known proven system used on F20 motors and also F20 heads run on K20 motors in british touring cars Regards Ian. |
08-21-2008, 09:16 PM
ae86 f20c header
Ian.G Wrote:Yep - they fit absolutely fine on LHD corollas - saves you a pretty packet thats for sure - That's great No Smorking AE86 |
08-21-2008, 09:44 PM
ae86 f20c header
Going Hybrid, Hybrid?
08-21-2008, 09:54 PM
ae86 f20c header
Just gathering info for now, should get started during the winter
No Smorking AE86 |
08-22-2008, 08:02 PM
ae86 f20c header
5k buys everything you'll ever need to F20 your car... From me.
If you do it yourself... Who knows.. Driftworks - JSPFab.com - DangerStyle - NightSpirit |
Hello from Auckland, New Zealand [AE85 F20C] | Tofu | 3 | 14,739 |
07-05-2009 01:17 PM Last Post: Tofu |
