air filter for swiss ae86 (AFM)
08-07-2006, 12:26 PM
is this good?
290014661178 http://cgi.ebay.com/ebaymotors/ws/eBayIS...%26fvi%3D1 somebody in europe selling one? |
08-07-2006, 12:39 PM
I really doubt that you'll acheive 8-15hp gain with this filter...
My friend put one of this filters on his honda ek4 togheder with cold air intake, and the car loosed power instead of gaining it. Anyway, you should look if the filter is suitable for AFM cars - it can't be munted directly on throttle body/intake manifold, because there's also afm between the filter and throttle body... Regards Andrej |
08-07-2006, 12:44 PM
They filter worse then ordinary paper filters and yield 0,0 horsepower on an otherwise stock engine. I'm guessing the AFM is a flapper door type, newer style glowing mesh/wire types get totally destroyed by the oil.
Best solution is still as big a paper filter as you can find. There is a reason that even sports car manufacturers keep choosing them over these, you know. A wheel to steer the front of the car A pedal to steer the rear |
08-07-2006, 12:45 PM
hey dreja how are you? thanks for the reply!
somebody has a picture of an AFM engine with sport filter? I can't figure out how the adapter looks like... |
08-07-2006, 12:46 PM
do you still have the stock setup like me?
if yes I thionk it wont fit... you wont gain a lot of power anyway... personaly I'll go for a replacment panel/ring filter from K&N... as long as you don't provide fresh air to the filter, wich isn't the case with those direct intake stuff nor with the stock setup unfortunately... probably best would be hacking a whole into the side of the chassi to root som fresh air directly too the filter but I don't fancy cutting my beloved 86. AE86 ex-daily |
08-07-2006, 12:55 PM
Robotype, I'm fine, thanks and you ?
Maybe this can help: http://www.pdm-racing.com/features/AE86_buildup.html Direct to the pics: http://www.pdm-racing.com/features/imag/...59_big.jpg http://www.pdm-racing.com/features/imag/...61_big.jpg http://www.pdm-racing.com/features/imag/...67_big.jpg Regards Andrej |
08-07-2006, 12:57 PM
Bean Bandit Wrote:do you still have the stock setup like me? exactly the same! even same body color...! is that my car?? Bean Bandit Wrote:personaly I'll go for a replacment panel/ring filter from K&N... how does it look like and where can I get it? if somebody here has one for sale it would be great. do you still find original filters in swiss? I can't get them in Italy... nice to meet you anyway. |
08-07-2006, 01:02 PM
if I remember right it's one of these http://www.knfilters.com/search/product....rod=E-2485
have a search for a K&N distributor and as for the correct filter by product number as I've seen wrong listings sometimes as there were other setups available... i.e. http://www.ntp.it/it/home.aspx never looked for original item AE86 ex-daily |
08-07-2006, 01:09 PM
I have the same stock setup too (AFM swiss version).
I've bought my original filter at Toyota dealer, it costed me about 25-30 euro. This was two years ago, I hope it can still be ordered. If no, try to look at Nipparts distributor, nipparts filter code J1322036 (toyota oem code: 17801-16010) Regards Andrej |
08-07-2006, 01:13 PM
Bean Bandit
the one you posted is for 4age MAP version... We have swiss 4agec version. Regards Andrej |
Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 4,052 |
01-07-2024 11:36 AM Last Post: CCB |
AFM to Map Conversion | ps13michi | 3 | 3,116 |
ITB filter options | mister86 | 1 | 3,385 |
12-06-2020 10:44 AM Last Post: Bean |
Air Cleaner Assembly | Hama86 | 7 | 9,272 |
10-29-2018 03:28 AM Last Post: Hama86 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 17,125 |
08-16-2018 01:36 AM Last Post: Bean |
