alignment issues after re-install of coilovers
08-01-2013, 12:00 PM
OK, so you removed the complete coilover assembly with spindles
and camber plates, put in an OEM strut/spring/shock/top hat assembly
for MOT, and then swapped them back.
All you did was take out two bolts at the bottom and undo three nuts at
the top ?? If that is all you did, the camber should not have changed.
Cheers... jondee86
Messages In This Thread
[] - jondee86 - 08-01-2013, 09:38 AM
[] - NBU - 08-01-2013, 10:44 AM
[] - jondee86 - 08-01-2013 12:00 PM
[] - NoHachi - 08-01-2013, 12:53 PM
[] - allencr - 08-01-2013, 07:30 PM
[] - NBU - 08-02-2013, 07:52 AM
[] - NBU - 08-02-2013, 07:53 AM
[] - NBU - 08-02-2013, 07:54 AM
[] - NBU - 08-02-2013, 08:14 AM
[] - Dino86 - 08-02-2013, 09:06 AM
[] - NBU - 08-02-2013, 09:52 AM
[] - totta Crolla - 08-02-2013, 10:28 AM
[] - Dino86 - 08-02-2013, 12:14 PM
[] - NBU - 08-02-2013, 12:22 PM
[] - zenki - 08-02-2013, 03:13 PM
[] - Ivan141 - 08-02-2013, 03:45 PM
[] - NBU - 08-02-2013, 06:49 PM
[] - allencr - 08-03-2013, 06:17 AM
[] - allencr - 08-03-2013, 06:18 AM
  PWR light issue and no brake fluid after winter storage magpie 10 2,482 05-25-2023 08:09 AM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,326 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Running issues sam3007 6 2,736 06-26-2022 01:34 PM
Last Post: Dave W
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 6,677 07-31-2019 11:28 AM
  Carina drivers! - Coilovers for a TA60/62 nyberrg 2 6,189 06-05-2017 10:03 AM
Last Post: nyberrg
