alt. question. is going stock to 130 amp safe?
04-17-2008, 09:20 PM
my alt. sucks, if the radio is on and i step on the brakes the radio goes out.
if i were to buy the 130 amp alt. would that fix the problem? would it cause any damage if i did? thank you Beater cars, they run fine.........till you need to use them |
04-17-2008, 09:26 PM
the standard alt should be able to run the car and a modest stereo,i would look at the wiring and condition of the battery,and get your alt load tested
04-17-2008, 10:18 PM
ok, but if it turns out that i should need more amps would it do damage to go with 130?
04-17-2008, 10:20 PM
I have a 80 amp, don't know from what model of toyota, the previous owner installed it to have some extra rally lights, don't notice the difference
280z '75 audi S4 B5 '99 KE25 '71 |
04-17-2008, 10:22 PM
no it wont do damage,it only produces as much as is drawn by stuff
04-17-2008, 10:38 PM
sweet thanks guys
04-18-2008, 05:01 PM
Power wires to the back of the alternator can fray and break off from vibration over the years. Check those carefully, sounds as if there's a problem with electrical power feed...
VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,370 |
82mm Stock compression Pistons | apardal | 4 | 2,749 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,379 |
Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 5,559 |
03-24-2019 04:10 PM Last Post: oldeskewltoy |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 5,824 |
02-20-2016 11:48 AM Last Post: Bean |
