alt. question. is going stock to 130 amp safe?
04-17-2008, 09:20 PM
my alt. sucks, if the radio is on and i step on the brakes the radio goes out.
if i were to buy the 130 amp alt. would that fix the problem? would it cause any damage if i did?
thank you
Beater cars, they run fine.........till you need to use them
04-17-2008, 09:26 PM
the standard alt should be able to run the car and a modest stereo,i would look at the wiring and condition of the battery,and get your alt load tested
[Image: AEU86 AE86 - alt. question. is going sto... amp safe?]
04-17-2008, 10:18 PM
ok, but if it turns out that i should need more amps would it do damage to go with 130?
04-17-2008, 10:20 PM
I have a 80 amp, don't know from what model of toyota, the previous owner installed it to have some extra rally lights, don't notice the difference Smile
280z '75
audi S4 B5 '99
KE25 '71
04-17-2008, 10:22 PM
no it wont do damage,it only produces as much as is drawn by stuff
04-17-2008, 10:38 PM
sweet thanks guys
04-18-2008, 05:01 PM
Power wires to the back of the alternator can fray and break off from vibration over the years. Check those carefully, sounds as if there's a problem with electrical power feed...
VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
  Digital speedometer on stock dashboard FanIsHere 0 1,362 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 2,742 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,341 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,553 03-24-2019 04:10 PM
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 5,820 02-20-2016 11:48 AM
