aluminium radiator
05-23-2012, 05:11 PM
aluminium radiator
But the weather show that issue different variously places. And i think not ever put smaller radiator than stock.
05-23-2012, 05:16 PM
aluminium radiator
[Walaki]D`Lair Wrote:ditn Wrote:Why not go to some local rallyshop or shop No local rallyshops or so? |
05-23-2012, 05:40 PM
aluminium radiator
ditn Wrote:[Walaki]D`Lair Wrote:ditn Wrote:Why not go to some local rallyshop or shop Rally life in Hungary is pretty much f*cked in the last few years, all it is about now is pure money washing... AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
05-24-2012, 12:36 AM
aluminium radiator
[Walaki]D`Lair Wrote:fax0815 Wrote:For what you want you could either run a normal AE86 alloy rad that sort of fits the genuine mounts, all you have to do is adapt the hoses. Not sure about the outlet diameter on the F20, but the normal Civic runs 30mm i.d. just like the AE86. If the S2000 rad bolts almost in it might be the better solution. You managed to overheat the OEM rad with a spal fan, now imagine a decent alloy radiator with the spal fan... problem solved. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
05-24-2012, 08:23 AM
aluminium radiator
i did order nice looking rad, lets see how it fit. i let you know..
Radiator & grill support panel (Levin) | FanIsHere | 5 | 2,093 |
11-14-2022 10:07 PM Last Post: Ivan141 |
Alu thick core radiator fitment | Gtsi-R | 5 | 2,929 |
01-26-2022 01:28 PM Last Post: Gtsi-R |
AE86 F20C swap - Radiator issue | mad.matt | 3 | 5,963 |
02-07-2018 05:14 PM Last Post: mad.matt |
Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 5,798 |
cool lower radiator hose | thanos | 4 | 5,472 |
