another 2 door coupe from belgium ;) from '86
10-25-2007, 10:54 PM
Hi there all off u . I allready introduced myself on the new mebers page http://www.aeu86.org/viewtopic/new-ae86-...ium/t/5840 and got the car finally at my place so the project begins
Pics whill follow soon. I allready had ordered the genuine parkinglights at work and they just get in today. offcourse I put them on the car as fast as I could Next : - Strip the car as much as nessecary - Sand the whole thing - Paint it in original metalic toyota colors (allready have some in mind ) - Update the supspension - Som other rims - Update the exhaust - Update the intake and thats about it for now I hope there not to much rust but I don't think thats the problem allready put her in the air today and checked the whole thing out again so I think I am a lucky bastard |
10-27-2007, 08:01 PM
Just started with som cleaning the interior. got the rearseats out , the rear sides out so only the metal and soundkillers ar still in I also removed all off the brachets for the seats and sides. pretty much rust free
I'm going to make an apointmentsoon with the paintshop ps : pics whill follow soon |
10-28-2007, 04:04 PM
just blow the engine today
but don't worry be happy going to get the engine out as soon as possible and do a full chepc up and changing everything so its gong to be new in the meantime the car is going to go to the paint shop and then the works really begin |
10-28-2007, 07:26 PM
That's to bad..good to hear that you're building her all up!
Was the engine bad when you bought it or did you go all crazy on it or what? |
10-28-2007, 07:32 PM
what happened it was running fine when i was in it yesterday
No Smorking AE86 |
10-28-2007, 07:42 PM
don't know what happened excactly :s did a few donuts and a few moments after the temprature goes sky rocket and my crankshaftbearings where broken or something like that :s I think its my fault
but its going to get all of the bearing and seals new original by toyota |
10-28-2007, 07:49 PM
haha hmm why invest in pistons and all that stuff if u wanted to keep the 16v engine, if u do it correct now it'll be good for a long time
No Smorking AE86 |
10-28-2007, 08:07 PM
the pistons don't going to be changed if not nessecary only the bearing and seals on the whole engine block no cams crankshaft or pistons r going to get changed if they r still good
(om int nederlands te zegge sorry voor de niet nederlandstalige een gewone volledige revisie kit van dichtingen en lagers(schalen) ) |
10-28-2007, 08:11 PM
Sounds like you blew your headgasket.
Gotta watch the water temp when doing burnouts. I got scarred one time when I was doing burnout in the poring rain. It was so wet that the tires spinned very easy, the engine revved high with ease. Water temp start rising also because of th high revs...so I slowed down for a bit. PS. I would also measure the crankshaft before ordering bearings to look if it's damaged or needs oversized bearings. |
10-28-2007, 08:28 PM
i'm going to check everything out don't worry
I do work in a toyota garage and I have som help if needed there I'm studieing the block right now got the manuals in front of me |
A Portuguese Hachiroku in Belgium (lots of pictures) | Lt86 | 25 | 21,296 |
04-05-2017 08:08 AM Last Post: Lt86 |
levin from Belgium - demee76 | demee76 | 46 | 61,103 |
08-28-2015 03:06 PM Last Post: demee76 |
Belgium project | Roger | 12 | 16,158 |
08-03-2015 08:46 PM Last Post: Roger |
belgium ae86 | boedtsie | 8 | 11,592 |
06-01-2015 05:25 PM Last Post: Lt86 |
'85 2door from Belgium | HybriD07 | 507 | 516,480 |
05-23-2013 11:43 PM Last Post: kowalskitk4 |
User(s) browsing this thread: 26 Guest(s)
