rebuild overhaul 4AGZE
09-29-2012, 04:22 PM
Hi Guys,
Since I want to drive the AE86 for some while, and almost completely finished the golf I cabrio GTD rebuild i now want to find some time to spend on the Toyota. it needs a fresh paint, and also the engine gaskets are not what they ones were meant to be. so start with the engine first ![]() to my opinion I have a jap spec AE92 88-90 GZE looking at the L-jet valve and DLI.. but had 142 whp at 0,6 bar pressure. model code would then be: AE92-BCMXR .. for bit more boost I am running a 175mm T3 pulley. I want to bring some engine parts away to mech shop to check. what parts am I looking for? some parts are an easy choice, but some still raise some questions Overhaul gasket set: (Toyota) 04111-16110 ARP studs and nuts: ARP studs M10 X 1.25 X 5.00 Part# AM5 .000-1lb 3) 1 10pack ARP nuts M10 X 1.25 X 7/16 12PT part# 300-8363 Head gasket standard is 1,2mm thick? but i want to install a "improved version" since i am running more PSI. what are the options? standard compression ratio is 8,0 for the 145 hp, and 8,9 for the 165hp versions. can I easy raise my compression rate by a other gasket. Bearings: what will be the best options for the main and rod bearings? Standard or aftermarket? size will depend on measurements. so can obvious not order them upfront. please some help with the choice! links to good shops are also very welcome. also looking for a price worthy exhaust header what will improve the performance, and also will do good for the temperature balance in the engine. still running stock 4age header. thanks for your help and input! Regards. Roel Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
09-29-2012, 05:04 PM
That's a lot of questions.
Gasket sets can be bought much cheaper aftermarket, anything but the head gasket is not that much better @ Toyota I would expect. If you haven't spun a bearing, chances are you can get away with regular sized ones. Cranks don't wear down if the bearings do their work, you can usually only fit undersized bearings after having the crank ground down. ARP studs: only if you cant get cheaper ones. These parts become critical when aiming for high rpm's, which is pointless on a GZE. Head gaskets: Toyota makes good quality ones, so staying OEM there is not unwise. I wouldn't bump compression on a supercharged engine without knock sensors. Either boost it harder with a turbo or bigger SC, or keep boost more modest and go with more compression. High compression and high boost can be a dangerous combination without some safeguards (like knock sensors, and an ecu that will know to pull some timing when it detects knock). OBX does nice headers for the lowest budget. Quality is okay from what I've heard (from Robokill), minor design flaw on a pipe transition without a step, but that's easily fixed. They also make a more expensive (470 dollar) high-rise header, but I'd guess it is a bit overkill for an unnaturally aspirated engine ;-) (and it comes awkwardly close to the distributor). That was my 2p (half of which is admittedly 50% 'knowledge' I scoured from the internet over the past 10 years). FABRICA MI DIEM, PVNC! |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 10,351 |
Rear Differential rebuild | chenfon | 10 | 10,146 |
AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 10,731 |
Rear Caliper Rebuild | mad.matt | 16 | 17,637 |
01-19-2017 02:19 PM Last Post: Project D |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,928 |
