blacktop rev limiter issue
02-13-2008, 09:07 PM
Hi all, I recently finished installing my 20v silvertop (with a blacktop ECU) in an SR5. I´m not sure if i´ts wrong but the rev limiter appears to be set around 7500 rpm (using the SR5 tachometer). What´s the stock RPM limit for the blacktop ECU, 8000? I think the tachometer is ok because the idle RPM is around 900. I´ll try using another tachometer but I wanted to find out if it was a known issue. The engine runs fine, it seems quicker than other 4AGs i´ve raced against.
Thanks!
02-14-2008, 01:30 AM
stock blacktop limit is 8500 Smile
02-14-2008, 06:49 PM
thanks, something is very wrong then, it´s a very large RPM difference for a tachometer issue. any ideas of why is the limiter set so low? I once read in another forum something about the 20v ECU setting the limiter around 7200 when the speed sensor was disconected or something like that? I tried to look for that post but I couldn´t find it.
02-15-2008, 03:47 AM
I think the silvertop retards the limiter to 7200/7500rpm or something when you disconnect the speed limiter, but for sure not the blacktop, I always drive with the limiter and it works perfect. RPM tacho's can differ I guess, because a friend of mine has a AE101/Blacktop , limiter reads @ 7400rpm and my AE92/blacktop reads @ 8200rpm.
[Image: AEU86 AE86 - blacktop rev limiter issue]
  PWR light issue and no brake fluid after winter storage magpie 10 3,217 05-25-2023 08:09 AM
  Fuel pump issue DJexor 11 5,845 04-29-2022 05:45 AM
  Clutch Issue Deaty 8 4,681 04-09-2021 10:26 PM
Last Post: Nakilad
  5th gear issue r.ave 1 2,766 03-14-2021 08:52 PM
  exhaust odor/idle MOT issue Ryo 7 7,796 07-15-2019 09:17 AM
Last Post: jondee86
