bouncing idle ?!
11-21-2007, 09:22 PM
bouncing idle ?!
hi all,
i got a bad problem... when my engine is cold, my RPM hops up and down (look at the video) IM FREAKIN OUT! if the engine is warm the rpms are normal (900rpm) please help me ;( greetings joy ah... HERE IS THE VIDEO: http://www.visualhype.com/rpm.3gp (right klick, save target as...) ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
11-21-2007, 09:54 PM
bouncing idle ?!
First look for low level coolant or air in your radiator cirquit. Then check your TPS setting .
AE86 FANATIC!!! |
11-21-2007, 09:58 PM
bouncing idle ?!
what are tps settings?!
11-21-2007, 10:28 PM
bouncing idle ?!
Look if the ThrottlePositionSensor is correctly installed.(black sensor at the right side of the inlet with rectangular 4 pined socket at the back)
AE86 FANATIC!!! |
11-22-2007, 09:34 AM
bouncing idle ?!
Most common cause is a faulty idle up air bypass valve (auxiliary air
valve) located under the throttle body. You can check by removing the air intake ducting, and putting your finger over the air port inside the throttle body. This is a round hole about 7-8 mm dia at the bottom and in front of the throttle butterfly. If the engine revs drop and stabilise when you block this port, it will be the AAV that is causing the problem. Check that you don't have air in the water circuit to the throttle body (pull off the hoses while the engine is running and bleed out any air bubbles). If that doesn't work, try taking the AAV off and cleaning it. If you still have the problem, buy a new AAV from Toyota Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
11-22-2007, 09:49 AM
bouncing idle ?!
Take a look here as well for the cooling problems:
http://www.aeu86.org/viewtopic/problems-...dle/t/5485 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
11-22-2007, 10:15 AM
bouncing idle ?!
thanks for your answers!
i´ll try these things... ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
11-22-2007, 03:44 PM
bouncing idle ?!
Similiar thing happens to me .. and only when cold and idle.
In my case it's not AAV or TPS. I'm preatty sure it's Cold Start Injector acting up... little clogged up. Or some fuel delivery problmes (fuel pump, fuel filter). Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
11-22-2007, 11:14 PM
bouncing idle ?!
Cold start injector only fires while the engine is cranking.
11-22-2007, 11:47 PM
bouncing idle ?!
had it a few days ago. Coolant!
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,484 |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,448 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
exhaust odor/idle MOT issue | Ryo | 7 | 7,325 |
20v silvertop idle issue | AlexFourTwenty | 3 | 5,195 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
Silver top low idle | AlexFourTwenty | 7 | 10,222 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
User(s) browsing this thread: 13 Guest(s)
