bouncing idle ?!
11-23-2007, 11:05 AM
bouncing idle ?!
jondee86 Wrote:Most common cause is a faulty idle up air bypass valve (auxiliary air
valve) located under the throttle body. You can check by removing the
air intake ducting, and putting your finger over the air port inside the
throttle body. This is a round hole about 7-8 mm dia at the bottom and
in front of the throttle butterfly.
If the engine revs drop and stabilise when you block this port, it will be
the AAV that is causing the problem. Check that you don't have air in
the water circuit to the throttle body (pull off the hoses while the engine
is running and bleed out any air bubbles).
If that doesn't work, try taking the AAV off and cleaning it. If you still
have the problem, buy a new AAV from Toyota Undecided
Cheers... jondee86
i think i need a new AAV! ;/
the engine revs drop to 500rpm!
http://www.sideways.co.at
11-23-2007, 12:52 PM
bouncing idle ?!
Listen to Jexor, check/fill the engine coolant Big Grin
11-23-2007, 01:12 PM
bouncing idle ?!
im a newbie....
how do i check the coolant?!
11-23-2007, 02:26 PM
bouncing idle ?!
Open the radiator cap (ONLY WHEN THE ENGINE IS COLD) and if you can't see the coolant - add some.
The expansion coolant tank must have coolant also - between MIN and MAX marks.
11-23-2007, 02:57 PM
bouncing idle ?!
ok i´ll try...
thanks!
11-23-2007, 03:06 PM
bouncing idle ?!
the coolant tank water is between MIN and MAX marks!
but there is nothing in the radiator!??
11-23-2007, 03:32 PM
bouncing idle ?!
So add premixed coolant in the radiator.
Or if you can buy only concentrated antifreeze - dilute it 50/50 with water.
PS: Most common antifreeze solution is ethylene-glycol based (so buy this type).
11-23-2007, 05:11 PM
bouncing idle ?!
i buy easily cooling water , ilute it 50/50 with water and fill it in the radiator?!
does it matter if its the same cooling water like the old one?!
11-23-2007, 05:35 PM
bouncing idle ?!
You can add non-diluted antifreeze, no problem with that.
Yes, it's better that you use same coolant but you can mix coolants of the same type (i.e. if you don't know what is exactly in your radiator: PS: Most common antifreeze solution is ethylene-glycol based (so buy this type))
11-23-2007, 05:49 PM
bouncing idle ?!
ok i´ll try !
thanks Smile
  No idle below 2000 rpm rich running Steller Engineering 3 2,798 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 11,397 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 9,662 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 6,511 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  Silver top low idle AlexFourTwenty 7 12,411 10-16-2017 10:22 PM
