bouncing idle ?!
11-23-2007, 11:05 AM
bouncing idle ?!
jondee86 Wrote:Most common cause is a faulty idle up air bypass valve (auxiliary air i think i need a new AAV! ;/ the engine revs drop to 500rpm! ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
11-23-2007, 12:52 PM
bouncing idle ?!
Listen to Jexor, check/fill the engine coolant
11-23-2007, 01:12 PM
bouncing idle ?!
im a newbie....
how do i check the coolant?! ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
11-23-2007, 02:26 PM
bouncing idle ?!
Open the radiator cap (ONLY WHEN THE ENGINE IS COLD) and if you can't see the coolant - add some.
The expansion coolant tank must have coolant also - between MIN and MAX marks. |
11-23-2007, 02:57 PM
bouncing idle ?!
ok i´ll try...
thanks! ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
11-23-2007, 03:06 PM
bouncing idle ?!
the coolant tank water is between MIN and MAX marks!
but there is nothing in the radiator!?? ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
11-23-2007, 03:32 PM
bouncing idle ?!
So add premixed coolant in the radiator.
Or if you can buy only concentrated antifreeze - dilute it 50/50 with water. PS: Most common antifreeze solution is ethylene-glycol based (so buy this type). |
11-23-2007, 05:11 PM
bouncing idle ?!
i buy easily cooling water , ilute it 50/50 with water and fill it in the radiator?!
does it matter if its the same cooling water like the old one?! ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
11-23-2007, 05:35 PM
bouncing idle ?!
You can add non-diluted antifreeze, no problem with that.
Yes, it's better that you use same coolant but you can mix coolants of the same type (i.e. if you don't know what is exactly in your radiator: PS: Most common antifreeze solution is ethylene-glycol based (so buy this type)) |
11-23-2007, 05:49 PM
bouncing idle ?!
ok i´ll try !
thanks ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,484 |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,447 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
exhaust odor/idle MOT issue | Ryo | 7 | 7,325 |
20v silvertop idle issue | AlexFourTwenty | 3 | 5,195 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
Silver top low idle | AlexFourTwenty | 7 | 10,221 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
User(s) browsing this thread: 16 Guest(s)
