bouncing idle ?!
11-21-2007, 09:22 PM
bouncing idle ?!
hi all,
i got a bad problem...
when my engine is cold, my RPM hops up and down (look at the video)
IM FREAKIN OUT!
if the engine is warm the rpms are normal (900rpm)
please help me ;(
greetings
joy
ah... HERE IS THE VIDEO: http://www.visualhype.com/rpm.3gp
(right klick, save target as...)
http://www.sideways.co.at
11-21-2007, 09:54 PM
bouncing idle ?!
First look for low level coolant or air in your radiator cirquit. Then check your TPS setting .
11-21-2007, 09:58 PM
bouncing idle ?!
what are tps settings?!
11-21-2007, 10:28 PM
bouncing idle ?!
Look if the ThrottlePositionSensor is correctly installed.(black sensor at the right side of the inlet with rectangular 4 pined socket at the back)
11-22-2007, 09:34 AM
bouncing idle ?!
Most common cause is a faulty idle up air bypass valve (auxiliary air
valve) located under the throttle body. You can check by removing the
air intake ducting, and putting your finger over the air port inside the
throttle body. This is a round hole about 7-8 mm dia at the bottom and
in front of the throttle butterfly.
If the engine revs drop and stabilise when you block this port, it will be
the AAV that is causing the problem. Check that you don't have air in
the water circuit to the throttle body (pull off the hoses while the engine
is running and bleed out any air bubbles).
If that doesn't work, try taking the AAV off and cleaning it. If you still
have the problem, buy a new AAV from Toyota Undecided
Cheers... jondee86
11-22-2007, 09:49 AM
bouncing idle ?!
Take a look here as well for the cooling problems:
http://www.aeu86.org/viewtopic/problems-...dle/t/5485
[Image: AEU86 AE86 - bouncing idle ?!]
11-22-2007, 10:15 AM
bouncing idle ?!
thanks for your answers!
i´ll try these things...
11-22-2007, 03:44 PM
bouncing idle ?!
Similiar thing happens to me .. and only when cold and idle.
In my case it's not AAV or TPS.
I'm preatty sure it's Cold Start Injector acting up... little clogged up.
Or some fuel delivery problmes (fuel pump, fuel filter).
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
11-22-2007, 11:14 PM
bouncing idle ?!
Cold start injector only fires while the engine is cranking.
Cheers... jondee86
11-22-2007, 11:47 PM
bouncing idle ?!
had it a few days ago. Coolant!
  No idle below 2000 rpm rich running Steller Engineering 3 1,528 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 7,603 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 7,408 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 5,234 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  Silver top low idle AlexFourTwenty 7 10,319 10-16-2017 10:22 PM
