brakes
03-29-2005, 12:57 PM
brakes
What brakes does a ae86 have in the front? How big are the disks? ANd howbig is the piston?
Broken down 1984 Trueno HB
[Image: AEU86 AE86 - brakes]
03-29-2005, 01:08 PM
brakes
234mm disks, 19-20 mm thick, vented (except Australian ones), 51mm brake cilinder, 1 pot, 140 mm between holes for brake caliper mounting.
03-29-2005, 01:30 PM
brakes
WHat diameter does the piston have?
03-29-2005, 01:32 PM
brakes
Quote:51mm brake cilinder
03-29-2005, 01:38 PM
brakes
Sorry. Thought you mean the master cilinder. Thx for the info.
03-29-2005, 01:43 PM
brakes
You're welcome !
PS: the master cilinder should be 3/4". But I don't actualy measure that (I will replace mine with AE82 1" one - measured).
  Rear brakes totta Crolla 0 1,063 02-03-2023 12:54 PM
Last Post: totta Crolla
  Switching diffs for disc brakes? trippin 6 3,115 07-08-2022 03:35 AM
Last Post: trippin
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,917 12-21-2016 09:37 PM
Last Post: bozu
  Hydraulic handbrake with stock rear brakes Dino86 11 16,154 07-11-2014 08:33 PM
Last Post: Dino86
  S13 Front brakes in AE86 rear heshan 25 29,495 02-01-2014 12:37 PM
Last Post: heshan
