bubbles in expansion tank?
04-11-2017, 02:31 PM
Hi,
just a quick question which I cant figure out at the moment. I´m having airbubbles in the expansion tank, constant once its warm and it does overflow a little one you race it. The waterhoses don´t feel like they are at 0,9bar. So I thought rad cap I´ve changed the rad cap for another one in unknown condition and it does the same. Rad cap seat in radiator hasn´t got any visible damage. Might buy an uprated rad cap like on all my other cars? I don´t suspect headgasket since the engine is 3000km old, and the head was skimmed and OEM gasket was used. It still does have all the original Toyota waterhose clamps everywhere. Am I missing something? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-11-2017, 11:27 PM
When you put your nose in the expansion tank while it is blowing bubbles,
does it smell like exhaust fumes ? Any water in the oil or oil in the water ? It may be possible for air to leak into the cooling system on the suction side of the pump while the engine is running. But if that was the case, there would be coolant leaking out when the engine was switched off. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
04-12-2017, 01:02 PM
Depending on the size of the leak in the cooling system you could possibly see white smoke in the exhaust.
Probably the best route is a compression or leak down test. It could possibly be a crack in the block or head. You could try re-troquing the engine head gasket. But since you have to pull the cams, it is almost the same amount of work as installing a new haed gasket. If do re-troque, only loosen one head bolt at a time. Using a center to out board sequence, using a troque wrench. Dave W |
04-25-2017, 01:49 PM
Went to a garage and we co2 tested the coolant, and it look like its head gasket, chracked whatever...
![]() 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-25-2017, 03:19 PM
That's too bad, hope it really is the gasket and not a crack anywhere (had that once, turned out to be a cracked block, in a daihatsu mind you).
If the gasket is ok, dont replace the head blindly without having it tested first. FABRICA MI DIEM, PVNC! |
04-28-2017, 04:57 PM
(04-25-2017 03:19 PM)Ivan141 Wrote: That's too bad, hope it really is the gasket and not a crack anywhere (had that once, turned out to be a cracked block, in a daihatsu mind you). Whouldn´t do that, there is a days worth of headwork in the head. ![]() 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
Fuel Tank Modification | apardal | 1 | 5,679 |
08-11-2014 06:59 PM Last Post: Ivan141 |
Pressure gathering in fuel tank | Apolan | 9 | 15,550 |
05-18-2014 06:18 AM Last Post: chenfon |
plastic fuel tank | bakonick | 12 | 13,258 |
12-26-2012 12:08 AM Last Post: bakonick |
Replacing the gas tank | amigaguy | 12 | 24,482 |
07-29-2009 10:36 PM Last Post: amigaguy |
ADVICE on- Emptying / Cleaning an AE86 Fuel Tank ??? | cue | 3 | 5,747 |
07-22-2009 12:29 AM Last Post: cue |
