cams cams cams
09-12-2013, 12:35 PM
Post: #31
cams cams cams
megabob Wrote:If i was looking at getting the catcams is there a dealer in the UK or will i need to go direct to catcams?http://www.catcams.co.uk AE86 ex-daily |
09-12-2013, 01:17 PM
Post: #32
cams cams cams
Bean Bandit Wrote:http://www.catcams.co.uk duh . Logic isn't my strong point today. |
09-12-2013, 01:20 PM
Post: #33
cams cams cams
i am thinking to buy the 256 type cams....i have oem rebuilded engine....european specs....
does anyone have 240 in a good condition by the way 4age 16v to FR 20VT |
09-12-2013, 02:49 PM
Post: #34
cams cams cams
megabob Wrote:If i was looking at getting the catcams is there a dealer in the UK or will i need to go direct to catcams? I went direct to Catcams in the UK even though they are shipped from Belgium. I got a 10% discount as well. There is a company near to me called Atspeed who also stock them, as well as Balance Motorsport |
09-12-2013, 02:51 PM
Post: #35
cams cams cams
Apsogos Wrote:i am thinking to buy the 256 type cams....i have oem rebuilded engine....european specs.... I've got some bigport cams for sale |
09-12-2013, 03:09 PM
Post: #36
cams cams cams
Alex170984 Wrote:Apsogos Wrote:i am thinking to buy the 256 type cams....i have oem rebuilded engine....european specs.... how much mate?send me pm if you want 4age 16v to FR 20VT |
09-12-2013, 08:20 PM
Post: #37
cams cams cams
I wouldn't mind putting some new cams in the 20V. The head has already been skimmed and there's a slimmer metal head gasket in there, so the compression has gone up a little, but I just want to add some cams that would both make use of that to give me a little extra power but not so much to take away from it's daily drive. Any recommendations?
09-12-2013, 08:29 PM
Post: #38
cams cams cams
Jezza_hr Wrote:I wouldn't mind putting some new cams in the 20V. The head has already been skimmed and there's a slimmer metal head gasket in there, so the compression has gone up a little, but I just want to add some cams that would both make use of that to give me a little extra power but not so much to take away from it's daily drive. Any recommendations?I don't have any experience with the 20V but I assume these http://www.catcams.co.uk/acatalog/7107411.pdf will do. You might even go for the 7107412 but I'm not sure how good the OEM ECU will handle those. PS don't be fooled by the similar total duration of the ...411s as they have steeper angles and would act like longer duration ones. AE86 ex-daily |
09-12-2013, 08:41 PM
Post: #39
cams cams cams
Thanks for that Bean. Thankfully I'm not running the OEM ECU, so I can get everything calibrated accordingly.
09-12-2013, 08:56 PM
Post: #40
cams cams cams
Jezza_hr Wrote:Thanks for that Bean. Thankfully I'm not running the OEM ECU, so I can get everything calibrated accordingly.Then I'd go with the ...412s if they seem to be as wild as it goes without changing springs etc... AE86 ex-daily |
User(s) browsing this thread: 22 Guest(s)
