camshaft
03-24-2006, 07:05 PM
camshaft
With origin pistons, valves and valves spring how many degrees of camshaft is possible to put.
This question is because if the camshaft degrees is too bigger the valves can be crach with pistons....
thank you for these other question Wink
juju
03-25-2006, 08:52 AM
camshaft
if you don't have innershim conversion its not recommended to go any higher than 9mm lift. the duration above 288 gets useless without higher lift so do the math.
camshafts of around
272 degree with 8.3mm lift are n1
  Question about camshaft CHACAMAN 2 3,834 07-07-2020 06:41 PM
  Camshaft ID kazi 6 7,849 09-26-2018 12:07 AM
  Anyone farmiliar with hks camshaft types for 4age? spill86 5 16,659 11-18-2017 11:36 PM
  Camshaft sprocket bolt size? harkes 1 4,780 07-03-2015 12:41 PM
Last Post: Dave W
  Camshaft questions d3nso 7 8,320 08-16-2013 11:19 PM
Last Post: jondee86
User(s) browsing this thread:
