camshaft
03-24-2006, 07:05 PM
camshaft
With origin pistons, valves and valves spring how many degrees of camshaft is possible to put.
This question is because if the camshaft degrees is too bigger the valves can be crach with pistons.... thank you for these other question juju |
03-25-2006, 08:52 AM
camshaft
if you don't have innershim conversion its not recommended to go any higher than 9mm lift. the duration above 288 gets useless without higher lift so do the math.
camshafts of around 272 degree with 8.3mm lift are n1 Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
Question about camshaft | CHACAMAN | 2 | 3,581 |
07-07-2020 06:41 PM Last Post: oldeskewltoy |
Camshaft ID | kazi | 6 | 7,489 |
09-26-2018 12:07 AM Last Post: oldeskewltoy |
Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 15,674 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
Camshaft sprocket bolt size? | harkes | 1 | 4,597 |
07-03-2015 12:41 PM Last Post: Dave W |
Camshaft questions | d3nso | 7 | 7,955 |
08-16-2013 11:19 PM Last Post: jondee86 |
