cluster conversion
07-31-2008, 03:43 PM
cluster conversion
i have a 86 kouki trueno with the dials in km/h, i have found a set of uk clocks and am wondering is it a straight with the wiring.
THE CLOCKS I HAVE ![]() THE CLOCKS I WANT http://cgi.ebay.co.uk/TOYOTA-COROLLA-AE8...0281009774 any help much appreciated The world without TOYOTAs, cant imagine it. |
08-01-2008, 05:57 AM
cluster conversion
Should have all the same wires. I doubt the plugs would have changed from pre- to post-facelift, but I can't confirm this.
On another note, where are you located, I would consider taking your old one off your hands. If you're in the UK my brother is in London. Chris |
08-01-2008, 11:26 AM
cluster conversion
The wiring is the same between zenki and kouki, so no problem there...
I did swap from zenki to kouki cluster in my trueno and found that the speed indication was off about 5%. This is probably due to it being calibrated for the slightly larger stock wheels delivered with the kouki EU model. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
08-05-2008, 06:26 AM
cluster conversion
Yeah not as easy as you think. Thank god there is a speed signal converter inside the digital cluster though.
05-13-2009, 01:16 AM
cluster conversion
Speed signal converter ?
Calibration possible or just km/h and mph ? thanks |
20v Blacktop conversion.... | Mylesmck | 0 | 591 |
04-29-2024 05:48 PM Last Post: Mylesmck |
Kouki to Zenki Levin grill conversion? | Mylesmck | 6 | 2,695 |
02-08-2024 10:30 AM Last Post: r.ave |
EUDM gauge cluster | banpei | 22 | 5,605 |
08-15-2023 10:48 PM Last Post: banpei |
EUDM cluster revelations | banpei | 1 | 1,436 |
06-23-2023 09:11 AM Last Post: r.ave |
AFM to Map Conversion | ps13michi | 3 | 3,614 |
