cluster not working correctly?
08-19-2009, 12:49 AM
Ok please dont flame. i've been searching around to find a solution to this problem. i bought my car without knowing my cluster is messed up.
Speed meter - doesnt work
Odometer - doesnt work
seat belt light - doesnt work
fuel empty sensor - doesnt work
check engine light - i think doesnt work
brake light - stays on
all other meters work fine
i took out the cluster to inspect it. light bulbs look ok. no burns on the back.
is there a way to fix this cluster or do i need to buy a new one...?
08-19-2009, 02:55 AM
Sounds like your wiring is fooked rather than your cluster. Find the electrical wiring diagram that Parrot posted up and the diagnostic manual. You can then work your way through by checking the fuses, wiring continuity, power, and grounding. If your wiring is solid, then the cluster is shot, but I would suspect other culprits first.
Chris
08-19-2009, 04:30 AM
Has anybody got a link to the wiring as I just looked but couldnt find it as I got simular probs
08-19-2009, 08:39 AM
AEU86.org has everything you need.. look on the main page, not the forums.
Often times these kinds of problems originate at the connection terminal from you wiring loom to the cluster. Try cleaning it up a bit (maybe use some contact spray or something to clean the corrosion of the contacts), and see if that helps.
08-19-2009, 12:59 PM
Here you go
http://www.aeu86.org/index/technical-ae8...topic=5158
Main page left hand side menus
08-20-2009, 11:02 AM
Just a stupid question: which hand drive to you have (LHD or RHD) and on which side of the cluster is the speedometer?
Also is the speedometer digital or analogue? Dumb question
BTW: you bought the car without driving it? Huh
[Image: AEU86 AE86 - cluster not working correctly?]
  Brake lights not working takumi_mt 2 807 03-07-2024 03:42 PM
Last Post: takumi_mt
  EUDM gauge cluster banpei 22 5,151 08-15-2023 10:48 PM
  EUDM cluster revelations banpei 1 1,323 06-23-2023 09:11 AM
Last Post: r.ave
  working out compression ratios kazi 2 3,692 07-16-2019 08:22 PM
  Custom Dash Cluster kazi 14 20,606 10-24-2017 09:05 PM
Last Post: kazi
