compatibility of rear harnesses
12-20-2014, 02:38 AM
As I am getting ready for my GTS swap I have a question about the rear wiring harness. The car all of my parts are going into is an 85 SR5 from an 86 GTS. Sincr the tail lights are a different design will there be compatibility problems going from Zenki to Kouki?
Thanks,
Dinkers
12-21-2014, 05:05 PM
Compare the wirecoulours, they should be identical, if there is anything in a different place change the pins over.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
12-21-2014, 05:08 PM (This post was last modified: 12-21-2014 05:09 PM by Uzelac.)
AE85 harness doesn't have wires for electric fuel pump, beside identical.
I have AE85 wires in my AE86, so I had to learn Smile
  Rear ae86 rear discs & pad part numbers? J-86 4 6,184 11-30-2012 06:32 PM
Last Post: J-86
  Adjustable Rear trailing arm/rear 4 links? lolali 1 4,834 10-03-2009 05:17 PM
Last Post: lolali
  rear brakes and rear axle questions fastsaab 5 6,447 11-19-2008 05:28 AM
Last Post: Chrisso
  steering rack compatibility mr monster 3 4,540 09-29-2006 11:51 AM
Last Post: mr monster
