compression, USA VS JAPAN
06-06-2007, 11:55 PM
was lookig at buying some standard pistons from america and was told this
Quote:Be careful IIRC the 4age in the US is not the same compression as the Jap engine so you dont want to screw the compression.
anyone know the truth to this
[Image: AEU86 AE86 - compression, USA VS JAPAN]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
06-07-2007, 01:07 AM
The Big Yin Wrote:was lookig at buying some standard pistons from america and was told this
Actually MOST members here know what you are GENERALLY speaking about, but the ACTUAL mis information is NOT the pistons from USA to Japan... but the piston difference between parts of Europe, and Singapore and EVERYWHERE else!
Only the "EUG" and Singapore 4AGE engines got a higher compression piston (10.0 to 1) all other markets got 9.4 to 1. In 1990 the world all got the high compression "Redtop" at 10.3 to 1
Dan -
06-07-2007, 01:15 AM
so US pistons wont work in my japan import engine in fact it will be a UK engine as i am just about ti fit a new one
06-07-2007, 02:02 AM
The Big Yin Wrote:so US pistons wont work in my japan import engine in fact it will be a UK engine as i am just about ti fit a new one
Dumb question
US and Japan used the same pistons... so did much of Europe, all of the middle east, and much of what is known "GEN" in the EPC (I believe general delivery) The ONLY two markets that didn't use the 9.4 to 1 pistons were the "EUG" and Singapore markets. Do a search... there is a thread in here somewhere showing the different part numbers
Dan -
  82mm Stock compression Pistons apardal 4 2,952 11-24-2021 04:26 PM
Last Post: apardal
  working out compression ratios kazi 2 3,699 07-16-2019 08:22 PM
  What is cranking compression on 10-1 4AGE? oldeskewltoy 2 4,832 03-24-2015 10:18 AM
Last Post: ditn
  What fuel are you high compression guys running? 4000GT 18 16,822 09-04-2011 07:11 PM
Last Post: IBMFD3S
  7age 16v compression Pif 1 4,781 10-12-2010 09:37 PM
Last Post: Pif
