costs
06-28-2005, 10:16 AM
costs
ok the car costs only 960eu but finally i payed over 1300eu for it with transport plates insurance etc...
i have problems with the ignition,
i change the plugs wires and see what happens
http://www.86ers.org
06-28-2005, 05:05 PM
costs
Also check out the timing...if you cant correct it by turning the distributor then it's probably shifted by a tooth..
06-28-2005, 05:45 PM
costs
sorry i founded new topic instead of reply, my fault.
i plan check timing and other things. what you mean by shifted by a tooth?
you mean the toothing between cams and distributor?
ok thanks i check this
06-28-2005, 07:57 PM
costs
Yes, it's possible that someone took out the distributor and put it back in wrong. It happened to me once. When you set your engine to top dead center on the no1 cilinder you can put it in correctly. Just line up the small punchmark and a line on the input shaft (or vice versa) and put it in as straight as possible..
06-28-2005, 08:15 PM
costs
i hope it is nothing with ecu or injection system.
06-28-2005, 08:35 PM
costs
injectors can be cleaned and ecu's well there all over the place :-) no prob about that
