crank 6 bolt flywheel
12-03-2016, 01:37 AM
hey guys, long time ago i bought an extra engine. now want to drop it in and it has a 6 bolt flywheel crank. how can i identify if its a 4ac one or a 7af?
[Image: AEU86 AE86 - crank 6 bolt flywheel]
12-04-2016, 09:18 PM
extra engine... if it were 7A it would be in a 7A block... Or did I miss something?? 7A stroke is 85.5, while 4AC would be 77. At that big of a difference you could likely measure the crank throws to see which it is closer too....
Dan -
12-04-2016, 10:06 PM (This post was last modified: 12-04-2016 10:06 PM by DJexor.)
(12-04-2016 09:18 PM)oldeskewltoy Wrote:  extra engine... if it were 7A it would be in a 7A block... Or did I miss something?? 7A stroke is 85.5, while 4AC would be 77. At that big of a difference you could likely measure the crank throws to see which it is closer too....
Absolutely true. I only have no idea how to visually separate the 4age block to the 7a block. I have heard that a 7a block with a 4age head is like a stroker mod to 1.8L engine. Would be nice if there is a way to see it without opening the engine.
12-04-2016, 11:42 PM
stick a long screwdriver through the sparkplug hole and turn the crank and measure the stroke. Very crude mthod but should do the trick. As mentioned by Dan the difference is big enough to distinguish the 2
Sent from my SM-T800 using Tapatalk
12-04-2016, 11:44 PM
smart one! thanks :-D
12-05-2016, 08:21 AM
Also you could check the block stamp on the side of the engine if it reads 4A XXXX or 7A XXXX.
Daily Beater: Civic EG5
Work in progress Car: AE86
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 18,110 08-16-2018 01:36 AM
  Cam Cap Bolt Snapped!! Alex170984 1 3,879 06-08-2018 01:17 PM
  light weight Flywheel filh 9 7,622 02-05-2018 05:20 PM
Last Post: filh
  brake booster difference zenki(2 bolt)/kouki 4 bolt v ditn 1 4,501 03-22-2016 09:43 PM
Last Post: ditn
  4A-GE 20V ITB bolt patterns kjb 7 12,459 02-27-2016 01:23 PM
Last Post: kjb
