crank scraper ??
01-11-2012, 10:34 AM
crank scraper ??
Have anyone investigated and maybe considered or even used crank scraper in 4AGE or any other engine?
My engine builder recommended to make one of steel and maybe add Teflon plate to tighten the clearance.
From what I've seen there is always an improvement in engine oil temperature (lower), often some gain in power (1-3%) and some even achieve higher engine speed.
Some details here:
http://www.crank-scrapers.com/
I think it can be cheaper if it's made on my own and definetly worth trying.
Any other thoughts ?
01-11-2012, 02:50 PM
crank scraper ??
4AGE scraper with teflon plate:
[Image: AEU86 AE86 - crank scraper ??]
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 18,151 08-16-2018 01:36 AM
  crank 6 bolt flywheel DJexor 5 8,367 12-05-2016 08:21 AM
Last Post: d3nso
  4ac crank on 4age! Ghetto 7 10,499 12-05-2014 10:42 PM
Last Post: Uzelac
  Crank pulley without harmonic damper Jan Pedersen 21 24,451 05-21-2014 09:50 AM
  Crank seal TheGerman 8 11,142 04-12-2014 09:36 AM
Last Post: Apsogos
